Remove lancer dashboard center air cond frame
Mon_key888
Hi bro's,:wavey:
Need advice on how to open my center air cond frame for my lancer E3 dashboard, my existing one got cracked so i bought a used one from mudah yesterday. I went to a shop and they quote me RM80(labour charge) just to install the frame. Anybody got any experience to DIY? i really appreciate your advice....:adore:
remove 2 screw top of the aircond control panel (digital control), then others is just a clip, slowly unclip all then can take it out.
Hi bro, thanks for your reply, i've tried that but it got stuck at the aircond hole.
  • H4PCA43FKBYCALOCK75CA5VU8JVCA4O7BCZCAPQUFL4CADM9K9ACANL568ICAH00VRNCAS436W6CA183JV0CAL0VHOCCAYV4.GIF
rm80.00 ???
wow its too expensive if you see the way to remove the dashboard centre frame...
first you need to remove the radio head unit. my Alpine just can remove the Head unit only while the player unit still remain there for easier process.
remove 2 screws at the top of digital A/C unit like bro cyilaw mention before.
then just a simple "umpil" the top section using screw driver,you're done(its using clip only)
the two "tombol " that circled in red, isn't connected to anything same goes to the right one that is used to control the blower for hot/cold air..it's also not connected to anything regarding to my lancer dashboard...for show purpose only
...good luck
