Redline D4 ATF
Redline D4 ATF
E3 Racing
2,000 RPM
Redline D4 ATF
Automatic Transmission Fluid Redline D4 ATF automatic / manual transmission / transaxle fluid. Our most popular and versatile ATF, D4 is suitable for use where Dexron III, Dexron II, or Mercon fluids are recommended. D4 ATF is designed to satisfy the improved low-temperature requirements which will be in the new Dexron IV specification, and the improved shear-stability requirements which will be part of the new Mercon specifications. D4 ATF also provides a GL-4 level of gear protection, making it a superior product for transmissions and transaxles like the Corvette's T-56. The balanced frictional characteristics provide smooth and consistent shifts for extended drain intervals. The superior stability compared to petroleum ATFs allows high-temperature operation without varnishing valves and clutches which leads to transmission failure. It?™s stability allows high-temperature operation without varnishing valves and clutches. Also provides improved shifting in cold weather.
FOR MORE INFROMATION.
Welcome To Visit Us:
** Full Address Of Shop As Below **
E3 Racing
Address : No.73A, Jalan 2, Pandan Indah Industrial Park, 56000 KL.
Business Hour : Mon-Sat 10.00AM - 7.00PM
Google Maps Search : "E3 Racing"
For more performance part inquiries, pls feel free to PM or
contact for more details.
+60123402733 (Call only)
+60182275515 (WhatsApp / Wechat~Available!!)
+60163322572 (WhatsApp / Wechat~Available!!)
Thank You.:driver:
