Radiostar for Ford Focus MK1?
ashabmy
I owned a Ford Focus, model year2000, CBU Europe. It has a double lock function, where the 1st lock will lock the car (but you can still open the door from inside). If press the lock button twice, it will active the DOUBLE lock, in which the doors are TOTALLY LOCK & can not be opened even from inside.
By installing the Radiostar, can I still use that function? and using only Radiostar remote control? Have you ever install it on the Ford Focus?
cheers
Hi is this a function of the car or the alarm that you have. If its the car I believe it will still be retained.
No not for a ford focus. Our authorized installer willl be able to advise you once he looks at your car. This will be the best option.
Call/email us if you have any further questions.
Thanks
integramania,
it is the car function.
BTW, do you any authorized agent/installer in Labuan (I haven't seen one) or Kota Kinabalu?
thanx
If its with the car i think should b a problem
Sorry no one is Labuan. If you have a trusted installer shouldn;t be aproblem since there is a wiring manual with diagram inside it
