Radio making noise
sexycar
4,000 RPM
Helppp... my radio has this brrrr sound after i went for an
aircon filter replacement & gas refill service in an aircond shop.
Before that my radio is fine. This is so funny, the guy didnt
touch my radio or fiddle with any wires. I'm only running two
6X9 at that back... can someone help or is there any ice repairers
in this forum? :omg_smile:
I think it must be any wires are touching, dont predict tat just aircond u did, it may cause problem also, have it consulted. Do u have fitted any noise cutters in ure player's wiring?
no man... i dont even know what are noise cutters. I'm not into ICE at all.
Only running a waja clarion cassete radio with 2 JBL 6x9 behind my old
1982 KE70 Corolla. Before the aircond servicing, my radio working perfectly
fine but all of a sudden after that aircond gas refilling both my rear speakers
emitted that brrrrr sound alongside whatever that is playing on the radio..
this is so irratating
the noise comes on during radio only or when u play casette as well. if radio only then maybe antenna wire came off or something. if noise for both then umight have to check all the wiring in case something got loose..
noise only on radio, cassette is fine. But no noise on cassette & radio
if i dont start the car... once i start ignition, noise will come if i 'on'
radio... I pretty sure the aircon guy bumped the positive side of my
battery while changing the aircon filter cos it's near to the positive side
of my battery terminal which is connected to loads of relays, voltage
stabilizer & loads of other wires
