Racing Parts & Others Accesories
huckaik
ELECTRONIC
1. APEXI EL BOOST METER 60MM (RM 200) sold
2. HKS FCD BOOST CUT FOR MIT (RM 150)
3. HKS FCD BOOST CUT & RPM CUT FOR MIT VR4 4G63 (RM 200)
4. HKS SLD SPEED CUT FOR MIT (RM 150)
5. HKS BOOST CONTROLLER (RM 400)
6. HKS PFC.F-C F-CON COMPUTER BOX FOR MIT VR4 4G63 [wiring & map sensor full set] (RM 850)
7. HKS AIR FILTER BOX FOR MIT VR4 4G63 (RM 150)
8. KNIGHT SPORTS FUEL CUT & BOOST CUT FOR MAZDA FC (13B) (RM 150)
9. LEVOC TURBO AUTO TIMER (RM 50) sold
10. LAUNCH CONTROL SYSTEM FOR MIT EVO 123456 & V6 & VR4 & MIVEC &
GTO (RM 200) sold
11. EVO 123 WIRING & SENSOR & AIR FLOW & INJECTION EXHAUST SENSOR (RM 1100)
12. VR4 RS WIRING & AIR FLOW SENSOR (RM 600)
13. TOYOTA STARLET TURBO EP71 COMPUTER BOX (RM 300)
14.Wira 1.8 DOHC wiring (RM 200)
FUEL PUMP
1. SARD RACING FUEL PUMP 280 L (RM 450)
2. BOSCH RACING 044, 280L, 10 BAR (RM 250)
3. NISSAN BIT FUEL PUMP (RM 100)
4. KNECHT RACING FUEL FILTER, GERMANY [NEW] (RM 50)
5. EVO 4WD FUEL TANK FOR WIRA AND SATRIA (RM250)
INJECTOR
1. DENSO INJECTOR EVO & VR4 550cc (RM 350)
2. EVO 8 INJECTOR 560cc (RM 500)
RACING CLUTCH & FLYWHEEL
1. CUSCO RACING CLUTCH & PLATE FOR MIT EVO123 & VR4 & 4G93 [NEW] (RM 1400)
2. OS RACING FLYWHEEL FOR MIT VR4 [NEW] (RM 500)
3. CLUTCH FOR MIT MIVEC & PERDANA & 1.8 WIRA japan ( o ) (RM 60)
SARD SILICONE HOSES
1. 6mm, 2 meters [NEW] (RM 60)
2. 6mm, 1.5 meters [NEW] (RM 45)
3. 4mm, 2 miters NEW (RM 50)
4. SARD FUEL REGULATOR (RM 200) sold
5. SARD RADIATOR CAP1.3kg (RM 40)
6. SARD THERMO WRAP 50mm, 10meters [NEW] (RM 300)
EXHAUST
1. APEXI N1 TITANIUM 3½” FOR TURBO (RM 400) sold
2. APEXI DUNK STAINLESS STEEL FOR NA (RM 450)
3. STAINLESS STEEL N1 3” FOR TURBO (RM 350)
4. STAINLESS STEEL 2” FOR NA (RM 200)
5. VR4 evo123 TURBO OUTLET V DOWN PIPE (RM 80)
6. DASH TURBO TCO5 ADAPTOR (RM 50)
7. HKS (O) HIPER SELENCER (NEW) (RM60)
SPARK PLUG & CABLE
1. ULTRA POWER PLUG CABLE FOR VR4 (RM 200) sold
2. NGK PLUG CABLE FOR WIRA 1.3 or 1.5 (RM 100)
3. VR4 PLUG CABLE (Original) (RM 100)
4. NGK PLUG 7EA FOR VR4 (RM 50)
5. SPLIT FIRE TRIPLE PLATINUM PLUG FOR VR4 (RM 80)
6. HKS F40RE PLUG FOR MAZDA FC & FD ROTARY ENGINE (RM 100)
SPORTS RIM
1. DAURA SPORT [JAPAN] 15” x 6½”, ET 45, (8) 100 – 114.3 hose c/w GOOD YEAR 15”x55x195 (RM 1000) sold
2. RIAL 13” x 5½”, ET 25, (4) 100 hose [GERMANY] (RM 100) sold
3. FONDMETAL [ITALY] 15” x 7”, ET 38, (4) 114.3 hose (RM 350)
4. ENKEI [JAPAN] 14” x 6½”, ET 24, (4) 100 hose 2 PIS (RM 350)
SUSPENSION
1. TEIN HA ADJUSTABLE SOFT HARD & PILLOW BALL UPPER MOUNT FOR TOYOTA JZX 100 (F) (RM450)
2. TEIN ADJUSTABLE FOR NISSAN SKYLINE R32 (F) (RM 400)
3. TEIN ADJUSTABLE FOR WIRA & VR4 (R) (RM 400) sold
4. EVO 7 ABSORBER FULL SET (F&R) [Original] (RM 1000)
5. BLITZ V,IS SOFT HARD ABSORBER MAZDA RX7 FC & (R) (RM 250)
6. VR4 PILLOW BOLL UPPER MOUNT (R) (RM 400)
7. PILLOW BOLL UPPER MOUNT FOR SUPER TOURING & ISWARA (F) (RM 200)
8. WIRA 1.5 SPORTS RACING SPRING (F) (RM 100)
9. EVO 3 (Original) spring (F) (RM 100)
10. FTO (Original) spring (F) (RM 100)
11. VR4 RS LOWER ARM & ANTI ROLL BAR (F) (RM 150)
12. SUPER TOURING RACING LOWER ARM & ANTI ROLL BAR (F) (RM 100)
13. AROSPEED ROOM BAR UNIVERSE [NEW] (RM 150)
14. R1 RACING ANTI ROLL BAR Bush [NEW] (RM 30)
15.GAB SUPER ABSORBER FOR WIRA (R) made in japan (RM200)
16.MITSUBISHI GALANT VR4 CUSCO (F) STRUT BAR (RM120)\
17.TOYOTA AE92 TOM’S (F) STRUT BAR (RM120)
BRAKE SYSTEM
1. SUMITOMO BRAKE PADS FOR CIVIC EG (F) [NEW] MADE IN JAPAN (RM 100)
2. WIRA 1.5 DISC ROTOR & BRAKE PADS & CALIPER & KNUCKLE (F) (RM 150)
3. NISSAN SR20 BRAKE PUMP (RM 100)
GEAR BOX & LSD
1. LSD FOR EVO123 VR4 4G93 GSR TURBO (RM 600)
2. EVO123 4G93 [4WD] LONG SHAFT (RM 100)
3. VR4 RS GEAR BOX (RM 500) SOLD
4. VR4 & 4G93 & EVO DRIVE SHAFT & CENTER BREARING SHAFT (RM 150)
5. VR4 RS GEAR BOX LOCK 2WD GOOD CONDITION (RM 600)
COOLING SYSTEM
1. VR4 RS & WIRA & EVO 123 RADIATOR (RM 100)
2. RACING OIL COOLER 17 ROW 12” X 11” (RM 200)
3. OIL COOLER 6 ROW 25” x 4” & 2” (RM 100)
4. VR4 RS A/C COOLING COIL (RM 50)
5. VR4 RS A/C COMPRESSOR (RM 100)
RACING PART & ACCESSORIES
1. MUKUNI RACING CARBURETOR (RM 400) sold
2. SCHROTH RACING SEAT BELT 4 POINTS (RM 100) sold
3. VEIL SIDE GEAR KNOB (RM 50)
4. AROSPEED CARON KEYLOCK [NEW] (RM 100)
5. WIRA 1.8 RECARO SEAT [FULL SET] (RM 600) sold
6. WIRA 1.8 MANUAL METER (RM 350)
7. WIRA SIDE MIRROR [1 SET] (RM 80)
8. VR4 RS INTAKE MANIFOLD & THROTTLE BODY & FUEL RAILS (RM 150) sold
9. VR4 RS IGNITION COIL (RM 100)
10. VR4 RS DISTRIBUTOR (RM 100)
11. VR4 & EVO123 ALTERNATOR 75AMP (RM 100)
12. VR4 RS VIPER MOTOR (RM 50)
13. VR4 RS METER CABLE (RM 30)
14. HOT BIT RACING COIL [MADE IN JAPAN] (RM 100)
15. VR4 RS STEERING SHAFT & COLUMN SWITCH & COVER (RM 100)
16. CUSCO BONNET PIN 1 SET NEW (RM 150)
17. EVO 8 RS2 TITANIUM TURBO (RM 2000) 18. MITSUBISHI GALANT VR4 SPEED METER AND RS SPEED METER (RM100)
SOUND SYSTEM
1. SONY XR7190 [MADE IN JAPAN] (RM 100)
2. ALPHASONIK EQUALIZER (RM 50)
For any INFORMATION, TECHNIQUE SUPPORT or PRICES kindly contact H/P: 016-4514155
Bro,
these items:
New or used? Original?
