Buds,
Having this vibration in my car. It happens after 100km all the way to my 180km cut.
1) Changed both rear drive shafts
2) Change rear wheels (borrowed)
3) balanced long shaft
4) Center bearings ok.
5) Tighten all main bolts on the drive train.
6) Vibration is on throttle, off and even with clutch in and on free gear
The rear view mirror is vibrating till I cannot see clearly through it.
Last thing I have not done is change the gear box bearing where the prop shaft sits. Kinda expensive last step but might consider it.
Any similar experiences?
My car is s a stock R33 GTS Series 2
Thanks.
Thanks
Thanks.
Thanks
