quetion:Bolt on turbo kit!
aries
All sifu~
If kenari(auto) original engin bolt on turbo kit~what should we need to taken care after installation complete?boost can to up how many bar?did the original piston easy boom? plsss~~give me some comment to using ori engine bolt on turbo~
bro,first before the instalation u need to culculate the compression ratio......and one thing if u did not change the piston........max boost u can go is 0.5 bar......i have already done this to a satria 1.3......but the engine does not last long.....banyak meragam......because,when u turbochrage the engine u did not change the map sensor.....this will confuse the ecu......so what u must do is u must change the map sensor and change the ECU.........
