Dude....
I have found one 1.8 hyundai coupe RD1,1997,mileage 98,000++ (manual),black at one of the second car dealer in PG, the price is stated RM35.8K. I have few questions as below, which need all tai ko to help me:
1)The engine was very quite, izzit a good sign?How do i check whether the car have oil leaking or not?
2) the air filter was change to K&N mushroom filter, should i request the original air filter? I worry that the air intake filter will suck in the heat air from generated by engine.
3) The left handside bottom door panel was break little bit, the plastic was break.....anyway to fix it? the sales agent telling me that he can repack the panel, will this solve the problem? Izzit possible for me to get new door panel? izzit expensive?
4)The rear screen has some blur blur yellowish, the area was 23cmX6cm, the sales agent told me that, just remove the screen tinted sticker and the yellowish will removed.
5)when i test drive the car, when i try to test the pick up, the power was not up to my expectation, currently i was driving wira 1.5 mannual,89hp, i was expect hyundai coupe with 130hp will give me some surprise ...but......izzit the car have some problem?
6)The absorber have some weird sound....can i the repair shop fix it or i need to change a new one? wat is the price?
7)When i switch the gear, i feel that the gear was loose, izzit normal?
8) the handbrake is loose too......
9) Should i ask for the certificate of puspakom?
would appreciated if you have help me to answer above questions........TT on me....if you travel to penang lah...
