u sure u want to install that cams ar?
google it first la bro...
Yes, I did read about one person who install and get worse results than stock. However, I am not sure if the ECU is tuned or not or what did the person do to his engine since he said it blew.
Hi! Any recommendations? I just need something mild around 260-270 degrees. The reason is that I will be supercharging my engine. Hence, I want slightly more aggressive cams to improve the high end a little.
Or do you think I should go for a CPS Head instead?
Thanks.
i think if u want to supercharge your engine... best to keep everything stock...
after all by supercharging it... u will definitely get much more power compared to those modded N/A's campro out there...
since force-induction theoretically wears out your engine internal's faster, why want to wear it out even faster by putting a high-lift cam ?
my 2 sen la...
If you still prefer to change to higher duration camshafts, I would recommend matspeed
matspeed cams are proven to perform what...
so many users with matspeed cams around....
as for the other brand.... errr...
who?
matspeed?
