normal guy
From Facebook
to sifu have been using lancer gt..do any problem with the car??? how much it cost about one time maintainence (change engine oil) ????
u mean Lancer GLX or Cedia? mine is GLX CS3A
bro first of all dont use to many ????? kinda irritating :) just ? or ?? ok already.
I must say its like maintenance cost of waja. max speed? its slowpoke. hehehe. get the converted one if u hunger for speed :) I mean those convert with Mivec or Evo or GSR. if u lucky enough to find GDI turbo much more better.
problem? I have no problem at all with my car. just that don't trash ur car too much (like I do) hehehehehe later u will pening kepala :)
consider very cheap edi.. hahaha.... fuel comsumption not bad ler.. about problem free? what problem u mean? factory defect? so far i will say NO... but if come with touch screen double din player will be GOOD la..
.. with every stock stendet gaban... with automode 180km/h can't go higher
Bro normal guy,
Quick response when using paddle shift mode... you will be amazed... and about the noisy stock tire i'm not quite agree... perhaps bro ong's little bro might have prob with toe in/out or maybe chamber... i dun have prob with noise with tire...
Service no need to worry la bro... not as high as evo's sifu here... 3-5k service.. but normal lancer clocking 10k km only service one... u do calculation la..consider very cheap edi.. hahaha.... fuel comsumption not bad ler.. about problem free? what problem u mean? factory defect? so far i will say NO... but if come with touch screen double din player will be GOOD la..
Max speed about 205km/h can't go edi (Paddle shift mode).. with every stock stendet gaban... with automode 180km/h can't go higher
normal guy said:problem anything about the car lor.. that means 1 service change engine oil around RM??![]()
if still thinking about service + labour + petrol + bla bla bla.. then u need a Good Calculator bro.... Endless counting la...
So far no problem with the car... stated ealier... 1time service cost u 3++ ler... consider cheap ler..
10k km only service once..if still thinking about service + labour + petrol + bla bla bla.. then u need a Good Calculator bro.... Endless counting la...
Before you buy, thinking about service la, petrol la this la that la.. after you buy, you will think another way.. "what shud i mod? what bodykit i shud change? what kind of rims? what kind of Exhaust? What engine should i put in? N/A? B.O.T? or even craziest but E-X halfcut la..![]()
this apply to STI Scooby too~ touge route is our destiny~! :proud::stupid:
dd05, my bro's gt is the facelift version. maybe they r using diff tires but for sure its very noisy. change new rims after 2 days n no prob with alignment/chamber setting.So far no problem with the car... stated ealier... 1time service cost u 3++ ler... consider cheap ler..
This is entry level a bit sport sedan and i can say it's in the middle between normal sedan and sport sedan. U cant expect much as it has been design to be driven daily in comfortable mode, not rally or racing type. It has a superb handling but not hardcore engines with turbine, just NA, but the same engine that used inside Evo X, so mean, turbocharged the engine and u will be fast as Evo X.
For paddle shift, so far no case that harm the gearbox, u can use it as it is, but trust me when times come, u will be lazy and will drive on auto mode, only use it occasionally, when want to feel the adrenaline rush, even Evo X owner also use the same method.
For engine, all the new Lancer use the same engine code, 4B11
Same engine and internal parts for GLS and GT
Same engine but different internal parts for Ralliart and Evo X
i wonder are there any lancer ralliart will be in malaysia ....the car soo nice laa but nt soo hardcore like da evo 10 laa.![]()
