PU Lower Arm Bushings
VectorX2
Hi,
I am wondering, whether changing the original lower arm bushings to PU bushings would make the ride uncomfortable? Will it produce any sound?
Thanks and regards.
To me, my experience by using Super Pro PU bush so far is normal feel cant really tell the different but very very kao expensive.
Other than that it is definitely a very durable bush.
durable yes... handling performance, if u dont push ur car to the limit, u most probably cant feel much...
personal experience... i swapped mine to superpro lower arm bush... during installation, my mechanic didnt tighten the lower arm strong enough... end result my lower arm was dangling dangerously with a loosen bolt... i felt no change in alignment as the car still tracks straight... the strong bush held my lower arm in place well enough...
