Mivec 1.8 Aeroback
Engine mivec:-
-racing con rod (forget brand)
-Piston 83 (oversize piston)
-Mivec Jun cam shaft with jun valve spring
-Acl racing bearing
-fully rebuild engine balancing - done by the specialist -
Performance parts
Titan Adjustable (just service)
Ultra racing front 4 point bar
front fender 2 point bar
upper rear ultra racing bar
upper rear absorber cusco bar
ultra racing side bar
lower rear FTO racing bar
full set front EVO antiroll bar with lower arm,& stering rack
Front and rear EVO III brake and brake servo
EVO III set padel with support clutch spring
EVO III radiator 2 layer come with EVO radiator fan and 2 speed aircon Fan
RIM 15" EVO I RIM
Tomei ori adjustable fuel regulator
AVS racing fuel Pump
AVS radiator hose
AVS Racing Plug
S-Pro-Series air intake Manifold
S90 Throttle body
HKS Racing fuel rail
HKS Cam Adjustable
HKS Crank Pulley
275 fuel Injector with support ballast injector
Haltech Standalone Sprint 500
Mugen Air Filter with the ram filter
Mugen twin loop muffler 2.3" piping
Interior
Full set EVO III dashboard till arm rest (armrest Telor) black in color
Mivec Meter (RPM10K)
DEPO fuel press meter
DEPO Oil press 4 in one (volt, Oil Temp & Water Temp)
Seat 1.6 brown in color
Steel Mate alarm 2 way - newly install -
Drive train
1.8 GTI gear box - Standard gearbox
4 Puck excedy clutch disc and pressure plate - Japan Make (can last for two years)
this machine drink Shenzo Oil 5-40 grade
Selling RM 29k (worth to buy!!!!!) depends on your budget nego
i build up this not for racing just for fun daily drive.
to build up this racing spec engine takes ages (TQ my patient foreman)
180 HP on wheel
torque estimate 180 newton meter torque
* Serious buyer Only.
* please check the spec before you call
* upgrade to 7 seater car
call klyap 0122098808
Ref Mudah http://www.mudah.my/Mivec+Wira-24250586.htm
Engine mivec:-
-Acl racing bearing
Performance parts
RIM 15" EVO I RIM
AVS radiator hose
AVS Racing Plug
S90 Throttle body
HKS Cam Adjustable
HKS Crank Pulley
Interior
Drive train
180 HP on wheel
