Check this out brader :)Originally posted by Danny@Mar 7 2004, 12:57 PM
Darn, my proton's roof got rust bubbles. I sent it for spraying but the bubbles came out again only after 2 weeks! How can this be solved in the most cost effective manner? Any recommendations on what to do and where to go?
all i can say is good luck.Originally posted by LAWRENCE_Q@Mar 10 2004, 10:31 AM
my iswara oso same,rust bubbles on roof n front bonnet, front bonnet too serious, so front bonnet changed, for the root, my case,i do welding, ask the mechanic remove inside, weld from inside, after tat polish outer surface till smooth smooth lah!!! welding tahan lama, (dun do fiber), i spray whole car tat time, so do it sekali go!!! for the welding, i pay extra 50 bucks if i not remember wrongly...
cut out isnt it illegal? ei? so taht means sunroof or no sunroof...when u change the roof that means its already illegal? then what are we supposed to do when the roof gets rusty?Originally posted by g88@Mar 10 2004, 09:16 AM
front and rear windscreen will need to take out. Cut from pillar.
you have to change the roof...any spot of rust will not stop there only...it will continue to spread...
