Proton Persona: got problem with projector headlamp
i got my persona mt Bline 7 months ago..last month i upgrade my head lamp to angel eye projector headlamp..the problem i got start 1 week after..angel ring out and in this month my projector lamp out..i also put on fog lamp before, the same problem i had..i dont face any problem in 6 month i use ori head lamp..
can anyone give suggestion to solve this problem...
i assume your projector headlamps are made in taiwan/china/local...even my old taiwan made sidelamps leaked water where during heavy rain or raining driving shows heavy water vapour in the lamp...but before blaming the headlamp unit..check your bulbs/wiring/connectors...could be possible chances, they are at fault also..
my personal advice, don mess with the wiring since its a brand new car...your current warranty is 175000km or 5 years........but once u modify, the will void it.
expensive if any of yr important parts spoilt...my 2cents
changing your headlamps actually voids your warranty...if you don't know much about wiring..bring i to a otai wiring shop.....i would avoid those lala accesories shops as those don't know shit about wiring..no offense..but too much bad experience with these so called accesories shops....but first thing you could do it check if the connection/connectors wire are exposed or burnt...if it is burnt/melted, quickly replaced it as it could lead to your whole car exploding if the body is exposed to life wire...becareful...lastime i h3 foglights used to blow out after a drive in the rain...when i finally check it, i found that that the fuse resistance used was too low...i replaced it wit a bigger resistance fuse...
