Project Z Week 10 : Car stripped and padding needed
Kevin Lee
1,500 RPM
https://www.zerotohundred.com/wp-content/uploads/2011/07/270985_10150692001690352_902185351_19535571_5983588_n.jpg
So we enter the 10th week where the car has been stripped bare-naked of its proud hide. The car exposes the wear and tear from the old age of the car. This car has been going through a lot of aging and you could see the amount of rust on the car.
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/264880_10150692001495352_902185351_19535570_2671452_n.jpg
Rust is my favorite bit of the car. Without dealing with rust, you do not know how badly your car has aged over time. The rust is just overwhelming. If rust is not your favorite subject, you could look away.
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/261743_10150692001325352_902185351_19535568_4523966_n.jpg
Here's the rear of the car, in the bootplace where it stores the spare tyres. Look at the never ending trail of rust. It's just as bad as cancer.
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/260112_10150692000890352_902185351_19535558_331947_n.jpg
And here's where the passenger area is, all the rust accumulated over time.
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/264379_10150692000690352_902185351_19535557_7784236_n.jpg
Since the body is fully stripped, I believe this would be great to put on some sound insulation padding, if the body has been properly fixed up and treated with rust repair.
https://www.zerotohundred.com/wp-content/uploads/2011/07/driver-door-dynamat.jpg
According to Dynamat's website:
Dynamat is a thin, flexible, easy to cut and mold sheet that actually stops noise causing resonance and vibration, by using visco-elastic qualities that promote vibro-acoustic energy conversion. In short, that means noise becomes silent energy.
I believe with enough sound insulation padding, the car would nicer to drive around, because the outside noise is deafened. Plus, the car would be easier to live without the need of bumping up your ICE (in car entertainment) to the highest volume, just to enjoy some great music when flooring the pedal on the car.
As I will be away for 1 month, this project is temporarily suspended and on hiatus till I return from Europe. I will bring in some great original stories from my visit in Europe. Stay tuned for more updates. I will sign off for a month today. See you guys next month!
Suggest you look into STP products. They are lighter in weight compared to Dynamat
Mm.....will it be strong . How is this analogy
Break a stick , easy huh
Break 20 sticks , not so easy huh
how about 50 sticks ?
Did you know that the lotus elise extruded aluminum chassis is bonded together ? Basically glue holds that car together, no welding no riveting :P
If you do it right , the diy riveting would increase chassis rigidity. Use the right rivets and remember to spray some paint primer or anti rust solution on the bare metal parts, ie the holes that you have drilled.
