Problem with Meter
ryukeong
Hi there everyone,
I have some problems and questions here. Please advised....!!!
Yesterday my Wira Meter Km/h (that show whats the car speed & the numbers that show how many Km that my car have run) suddenly stop functioning. I heard that it should b a smalll problem, maybe is the wire connection loose oledi. Any idea?
So now i intend to remove the meter to checked, this is my first time, so then for wira is it easy to remove it? Only remove the screw and take it out? Do i need to be careful on anything?
And since i m going to remove the meter, i intend to change the light bulb color of it, so for the Auto meter how many bulbs there are? is it easily to get it change? i mean just like other bulb....pull / twist it to remove and replace it only?
R there any purple color bulb for the meter available? Anyone know how much does those bulb cost? And will it be as bright at the original?
Thanx very muchy :_:
juz to share with u my past experience with my speedometer...
perviously,the speedometer in my 4g15 will occasionally stop running...
even when my car is smoving......
so i tried to tap on the meter panel using my fingers then it works again...
after consulting my friend, he told me tat the speedometer cable might b loose...
he took out the speedometer cable( the 1 wear the cable runs from the gearbox into the firewall), there is a steel cable inside the cable....
he turns the steel cable he ask to to seee wheter my meter is running or not.....
indeed its runs....
after he fix back the cable then till now i didnt face this prob again...
(abt 2 months le)
maybe u wanna check your speedometer cable 1st b4 u remove ur meter....
coz i feel its much more easier then removing the whole meter....
you might wanna try turning the steel cable inside the then check whether your speedometer works or not.....
if it doesnt work, then you can consider removing you meter.....
juz my 2cents......
