Problem with hand brake
kk13
Hi guys,
I have a problem with my hand brake.
Example: When your on a hill you stop and pull up the hand brake. Then when you want to go you step on the accelerator and ease of the clutch. Then when you feel the car pulling forward you put down the hand brake right.
With my car, when you start to step on the accelerator and ease of the clutch, before you can even feel the power, the engine dies!
Any idea on what is the problem here? and how i can get it fixed? :confused:
Thank guys...
could be the handbrake cable jammed,the hand brake adjustment too tight or the mechanism inside jammed...
just send to ur mechanic to check it out...
