Prob with my EG : Kindly help...
azhargoth
Hi all..
Im currently driving a civic eg (soch) kinda having some problem with my car lately... the car tends to have a kind pullback feeling (sluggish) when accelrate on and off, on and off.. or when driving at idle speed for a quite a while..i can feel it on and off when steeping the pedal. The best part when the pullback feeling comes on and off i'd swith off the air-con and it gone for a while..on back the air cond 10mins later it comes back.
FYI - i've just changed my fuel pump (2 month ago) no problem after changing it until now, recently change my a/c compressor (1 month ago) :confused_smile:
Hope anyone could help me configuring what is the main problem...could it be the clogged injectors...distributior..o2 sensor, a guy told me maybe my oil tank is consume with water?? oh ya sometime my cokpit smell like fuel fume..
Thanks all..
Go have a check on your aircond compressor.Too much gas I guess.You just serviced your aircond recently, I assumed?
I've faced this kind of problem before.
or else try to check ur oil filter. cost u less than rm10 i guess..just a suggestion though..used to hav this kinda problem oso.. :_:
i dont know if it applies to honda cars but my fren once had a similar problem with pull backs. changed his distributor and his spark plug cables and it was all fine. you might wanna consider that?
hi all thanks for the reply:
for EG8
yup!! recently i have service my a/c after there is a leaking with the a/c hose connector thingy..and hv pump in new gas...might be the cause..
1908
Just change my oil filter and engine oil 3 weeks back can it be clogged so fast..?
NoNac
Hah..i tot that also 1st on my mind....i will checked it, maybe a poor cable..
Thanks guys..but the air cond gas asumption is quite making sense seems the problem gone when i switch off the a/c...anyway will tell u guys the results what is the main reason.....
Rgds..
