Power Windows
fat_returns
I've a 14-year Suzuki Swift and 2 of the power windows and auto lock are not working. Was wondering if anyone could recommend a reliable and cheap accessory shops in PJ/USJ/Subang/KL to have these fixed/replaced?
Really appreciate the advice
[snapback]907938[/snapback]​
:D Ur power windows is not spoilt but it seem like the wiring maybe problem.. Yes also the gear motor is not working anymore. So where u can find the orig? Actually no..
But here i gv u the tips. Go to any car accessory/spreparts shop ask them the kancil power windows motor..... U can bring to compare. The diffrent is u can see at 3 holes screw and one not match. So If u lazy to modified just put back and tight with 2 screw at the mount at ur pwr windows. If u hv time u can make or drill one new hole.
My car 2 front door using kancil motor.. 1 year plus now. For ur autolock.. Check wiring. If u success just gv info to ur group/friends. I hope it can help u b'coz it cheap and easy to find.
Ok thanks :ph34r:
very well said cultus.
however, my power windows now either go up/down very slow. this is probably because of the worn out rubber sealings. hehe. too bad no NEW replacements. sigh
[snapback]909387[/snapback]​
:D Hii.. U can find custom at any sparepart shop. Need little modification at rubber bfore installation.
2 types of rubber one is rubber only and one rubber with carpet(look like). Just see urself.
:ph34r: Ok..
