Standard maa.Legendary power window problem,Well you can try at Greenwood,one row with tyre shop there have 3 workshops,with different expertise.If stuck like you said it is possible of two thing,your power window gear has jammed or window bracket (White thingy one holding the glass,when open the door trim you can see)break.Cost around RM 150 above.:regular_smile:
