Power FC, need boost controller?
ahloy74
Hi all sifus,
If i were to use Power FC to adjust my fuel and ign signal, do i still need boost controller?
What i understand is boost controller is to control desired boost up to factory setting. By using
Power FC, the setting can be elliminated. So why is boost controller ever reqiured?
Unless for safe fuel setting, and track setting....Am i correct? Thks.
Power fc as an ecu to control engine parameter also it can be done for boost controller but need seperate device.
Boost controller to adjust desire boost lets say 1.2, 1.3 and so on...
i m using power fc but problem with idling rpm, no idling bro. Already changed trottle body but it same problem, any advice
Bro kojai, we are not sure wether your pfc or your car is at fault. I suggest you plug your pfc on your friend's car( having same model) and find out. If the defect transferred means your pfc is faulty( provided your friend's car idling is ok before that) if not, you got to troubleshoot your car system. Just my opinion...
You can perform a sensor check under the ETC menu when the key is in ignition turned to ON position. There you can see if there is a problem with any of the sensors. Good place to start at least.
hello friends,
Some clutch will contribute in knocking no.Is it true?
Does Mega-Rich setting will eliminate knocking?
