Item(s):
Soundstream TRC.6 RM700 Highend Component
6-1/2" 2-Way Component System
Die Cast Aluminum Baskets with CNC Cutting
Aluminum Alloy Cone and Dustcap
Butyl Rubber Surround
Conex Spider
Chrome Plated Top and Bottom Plate
Vented Pole Piece
1-1/2" Hybrid Silk Dome Tweeter
Neodymium Tweeter Magnet
3 Mounting Options: Flush / Swivel / Surface or Angle Mount
Ferro Fluid Cooled Tweeter
18dB Impedance Compensating Passive Crossovers
Tweeter Protection
Tweeter Attenuation: -3, 0, +3 dB
Gold Plated Binding Posts
1-1/4" Kapton Voice Coil
13 oz. Magnet
Impedance: 4 Ohms
Grilles and Mounting Hardware Included
Crossover Dimensions: 6" L x 4" W x 1-1/2" H
Soundstream LW4.500 RM799 4ch amplifier 4x60RMS
http://www.soundstream.com/images/products/main/amps/L31.jpghttp://www.soundstream.com/images/products/main/amps/L32.jpg
4 ohms: 65 watts x 4 chan.
2 ohms: 125 watts x 4 chan.
4 ohm: 250 watts x 4 chan.
MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Variable unbalanced input level control
Dampening factor: >250
Soft turn-on circuitry
Preamp RCA outputs
DC, speaker short, thermal, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 15-35 Hz)
Dimensions: 11.42"L x 9.45"W x 2.52"H
Soundstream TRX4.300 RM1099 4ch amplifier 4x50RMS
http://www.cartuningevolution.com/Files/20108/8137113344546.jpg
4-Channel Tarantula series Amplifier
RMS Power @ 4-ohm: 50W x 4
RMS Power @ 2-ohm: 75W x 4
RMS Power @ 4-ohm Bridged: 150W x 2
THD: 0.05%
Class A/B Topology
Fully Regulated PWM Mosfet Power Supply
Tri-Guard Amplifier Protection
Bi-Linear Selectable, Infinitely Variable Crossovers for Inputs and Outputs (HP/Full/LP)
Platinum RCA and Power Inputs
Tri-Mode Capable
Hi Gloss Piano Black Finish
End Caps for Professional Installation
Variable Bass Boost
Dimensions: 11"(W) x 2.6"(H) x 16" (L)
Soundstream TRA960.4 RM1399 4ch amplifier 4x120RMS
http://s.lowyat.net/uploads//attach-88/post-211188-1234900670_thumb.jpg
NUMBER OF CHANNELS: 4
OUTPUT (WATTS):RMS @ 4 Ohms 120x4
RMS @ 2 Ohms 240x4
RMS Bridged @ 4 Ohms 480 X 2
T.H.D.: < 0.02%
Frequency Response (Hz): 10 - 50k
SIGNAL TO NOISE RATIO: >115dB
DAMPING FACTOR: >500
INPUT SENSITIVITY: 0.15 - 12.0V
CROSOVER SLOPE: 12dB
CROSSOVER FREQUENCY (HZ): 50 - 5k
DIMENSIONS (INCHES): 10.75x2.6x21.5
Variable hi pass, band pass, low pass
Variable 18dB bass boost
Double sided glass epoxy SMT circuit board
PWM mosfet power supply
Tri-guard amplifier protection
SMT cooling fan built in
Tri-mode capable
Line output
Package includes: Amplifier, mounting screws, fuses, manual, warranty card
Price:
TRC.6 6.5" 150watt component RM700 nett self import with 1 year registered warranty
LW4.500 RM799 self import with 1 year registered warranty or RM999 by MAT
TRA960.4 RM1399 self import with 1 year registered warranty
TRX4.300 RM1099 self import with 1 year registered warranty
Warranty: All with 1 year by Soundstream
Dealing method: COD/pos
Location of seller: Sri petailing or bukit jalil
Contact method/details: 016-3634000
Age of item: bvrand new in box..sealed
Item(s) conditions: 100% new, not used, not refurbished
Picture:
Reason for sale: just to earn some side income and offering you guys greater stuff
Conex Spider
Vented Pole Piece
Tweeter Protection
13 oz. Magnet
Impedance: 4 Ohms
MOSFET power supply
Preamp RCA outputs
THD: 0.05%
Class A/B Topology
Tri-Mode Capable
Variable Bass Boost
RMS @ 2 Ohms 240x4
T.H.D.: < 0.02%
Tri-mode capable
Line output
Price:
Picture:
keep my post up
