pls give some feedback..thanks
TypeRwannabe
hi guys.. im building a totally new ice system.. and what i've come up with is ..
HU : Alpine CDA-9856
Specs : Includes iPod Direct Cable
50W x 4 (Max), 18W x 4 (RMS) Power Amplifier
3 Pre-Outs
Pop-up Rotary Knob
MP3 / WMA Playback
MP3 Text Information Display
Full Flap Face Design
Bass and Treble Centre Frequency Control
Remote Control Ready
Quick Search
AMp : Alpine 4ch MRV-F545
Specs : 125W x 4 RMS [4Ω @ 14.4V 0.08% THD]
125W x 1 RMS [4Ω @ 14.4V-BTL (1ch/2ch) 0.3% THD]
100W x 4 RMS [4Ω @ 12V 0.08% THD]
S/N Ratio 96dBA (IHF A Weighted Reference at Rated Power into 4Ω)
Thermal Management
500W x 1 RMS [4Ω @ 14.4V-BTL (3ch/4ch) 0.3% THD]
Comp: Alpine Type X - 177R
Specs : Peak Power: 300W
RMS Power: 75W
Frequency Response: 35Hz - 60kHz
Wood Fibre Cone and Phase Integrated Dust Cap
Custom Cast Aluminium Frame
Airflow Optimised Dual-Flare Pole Vent
1" Ring Radiator Diaphragm Tweeter with Wave Guide
Tweeter Protection Circuit
Bi-Amp / Bi-Wire Capable
3-Way/Dual Midbass Ready
Gold Plated Terminals and Connection Jumpers
Sub: Alpine SWR-1222D Type-R 12 x 1 unit
Specs : Power Handling (Peak): 1500W
Power Handling (RMS): 500W
Frequency Response: 24Hz - 500Hz
Nominal Impedance: 2Ohm+2Ohm
Sensitivity (SPL@1W/1m): 85dB
Installation Diameter: 275mm
Depth: 195mm
Kevlar Reinforced Pulp Cone
Custom Cast Aluminium Frame with Integrated Perimeter Venting and Heat Transfer Plate
Dual Voice Coil Design
HAMR Surround and Concealed Mount Gasket
Insert Push Terminals with One-sided Layout
Designed and Engineered in the USA
The question...is there anything that I need to change or add to give both..SQ and SP..but the main thing is of course SQ.. and I havent decided any RCA and speaker cable to match my system... hopefully u guys can guide me.. and I'm looking to spent about rm5~6k max and i just got quoted by one of accesories shop at SS12 for the above system..cost me about rm4.8k..is there any place that i can get it cheaper..? and of course..a good workmanship...
i calculated 4.8k also with best price for KF audio in aman suria. good setup but feel better if u get a better HU, the 9856 is entry level only....
can save bit more money if install under front seat instead of the back. shorter RCA, power and speaker wires...
installation included but not the cost of cables and wires. usually labour is free with purchase of amp/speaker or HU. maybe up one model la, get 9857 is quite ok..
mayb can try eclipse 3414... 5V pre-out... i think is higher than the alpine... if i am not wrong... around the same price range as the alpine too...
unless you wan a full alpine setup la... just a suggestion...
as for cables... agree with zenn... under the seat to save more money...
cheers...
u work at KF is it..? can give me the contact person there..might drop by over there this wednesday to have a chit chat... and yes..actually i wanna have a full alpine setup...thanks for the opinion thought...
i used to work there for a while. if u go there look for mr liew and tell them youre a forummer. if he's not there or is busy, u can talk to Emad the supervisor, or Woei Chern the senior installer..
will drop by KF Audio tomorrow to get the quotation..yea yea..hopefully their shop is open until Friday...so can install my ICE b chinese new year...
UR36 means it is 3 way, so definitely better than 2 way type x. however, u have to make sure it is original UR bcoz got lot of imitation in our market. check for distributor sticker and warranty card. should be from NTC..
haiya..sorry to trouble u guys again..got 1 question about my speaker wiring..got quoted today for wireworld (white color and flat type) 1meter is rm26. As for the interconnect rca, its streetwire zn6 5meter for rm400.. the question is..
is the price ok or cekik darah type..and how about the performance compare to other brands in that kind of price range...
thanks to all sifuss
just get whatever you can afford. To spend 400 on RCA alone is a waste. You can upgrade other things with that money. Just make sure that the RCA is properly connected and three is no tear on the cable jacket.
