please help RSM apexi
azahari.aziz
anyone know how to measure HP(PS) using rsm apexi????
when i turn measure -->power... it didn't show any thing... how to used or my rsm need to repair???
bro. u need G-Sensors.. then u can use the function!
This unit plugs into the Apexi RSM
The G Sensor allows the unit to measure G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G's on the race track, or used in an array of new features including: Highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, Horse Power Calculation, and Loss Power Calculation. By taking advantage of the optional G Sensor, the user can produce extremely accurate power measurements. Usually, when measuring 0-400m times through the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. Using the G Sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times.
