Pivot RAIZIN Volt Stablizer
RyanKent
Selling
http://pivotjp.com/product/raizin/img/raizin-menu.jpg
http://img451.imageshack.us/img451/8623/razinbul7.jpg
http://img442.imageshack.us/img442/3566/razinb2nk0.jpg
Pivot RAIZIN Volt Stabilizer [blue]
rm150/set
Pivot Raizin Volt Stabilizer
PIVOT Raizin volt stabilizer, comes with options: with or without Super Earth spark plug earth tune-up system. Including all installation hardware and manual, made in Japan.
- Increases torque at low and middle speeds.
- Stabilizes idling and improves engine kink-over.
- Improves engine response.
- Increases headlight brightness.
- Improves fuel economy.
- Improves battery life.
- Improves bass sound.
http://pivotjp.com/product/raizin/img/vs-s.jpg
http://img440.imageshack.us/img440/5239/miscintvss1hn6.jpg
http://img362.imageshack.us/img362/6347/miscintvss2ur7.jpg
http://pivotjp.com/product/raizin/img/graph-vs-s-e.gif
PIVOT RAIZIN Spark VS-S Ignition Voltage Stabilizer[red]
rm280/set
Until now, due to various types of load resistance and interference at the contact terminals, fuses, contact points and cords in the electric circuitry on the way to the ignition coil, major loss occurred and optimum combustion did not take place. To help solve this the Raizin Spark utilizes a new approach in voltage stabilizer devices for ignition coils that brings out 100% of your ignition's performance by providing point blank power to the ignition coil via connection to our specially designed circuitry. This in turn gives you dramatic improvement in engine performance from optimum ignition to ideal combustion.
Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
Pivot's exclusive newly designed condenser, which includes honeycomb shapes in various places, has superior frequency response characteristics that help to bring about incredible noise reduction and results in more stabilized voltage, as well as, achieves both optimum high frequency wave responsivity and improvement in electrical capacitance.
Made in Japan.
http://pivotjp.com/imitation/imitation-raizin-e.html
notice for fake pivot stuff
charge rm5
delivery within KL area by pos laju
COD: KL sentral / KTM Station / LRT station
contact :0162668138 / 0163373368 kent
kindly call/sms me if intersting
thx"
chalexcity said:
bro your raizin blue confirm ori as a lot of imitation out there lor
check this link out!!
my pivot stuff 100% original~
ok bro thanks for the clarification anyway before confirm can show photo of the your raizin selling , possible ? vs eg as shown on the pivot web site . thanks bro
i will send the pic for u 2molo!
my stock 100% same with the pic on the pivot website!
thx for support
bro,
is it easy to install to our car(pivot raizin volt stabilizer)?
i know that is a blue light to indicate whether wrong or right installation, is it true?
ya its very 2 install~
just follow the instruction wif the pivot raizin!
thx for support~
all pm reply
what is the best price for volt stabilizer + ground cables? is it necessary to install the 5 ground cables? what is the purpose of it, mine explain. is it suitable for wira 1.8 sohc, naza ria and toyota unser?
can we feel the different clearly after install?
hope to hear from you soon.
