Performance Friction
what u mean by performance friction brake disc??...
rotors??... calipers??... brake pads??...
mayb can try enquire GRIPPEN brake sets...
what car u driving??...
Performance Friction is a brand name.
The parts I'm looking is only the disc/rotor
I am not looking for the caliber or pads.
Don't think you can get PF's stuffs here. Last I checked they don't even have a dealer in Singapore. Probably Hong Kong, but Japan is one of the Asian country they have a distributor in. Check their website again.
BTW, what you have in mind? The normal rotors or the carbon rotors?
the normal one
The normal rotors eh?
Well it's not much different than your run-o-the-mill aftermarket performance rotor. If it's readily available, then go for it. If they require you to be a dealer, then forget about it.
Not sure if I got it wrong, but I think PF is an OEM for BMW. Try checking with the BMW parts dealers on brake rotors for E46 M3 and onwards.
Thanks for your infor. I'm looking for evo rotor. In UK they gave a lot of goord reponse in combination with brembo caliper.
