Perdana v6 into evo2 engine swap
I using evo engine under my v6's hood.
Driveshaft left (short) use evo with hanger, right (gearbox) using V6 auto drivesahft.
Mounting gearbox can use the 4wd manual OR aftermarket, left right used v6.
what else u need to know and curious just ask the forumers..
Happy Boosting.
did my homework..one more quetion all seefuu...can eterna trotle body masuk into v6?and if can would it effect air induction?does 3 layer radiator /pajro twin fan helps cooling ?oil cooler +hosing etc involved?amm i making sense?(i prefered N.A then changing into turbo engine{eterna/vr4/air trek turbo/evo's as i found that this jentera is very the manjaa!:\....advised my seefuzzz:banghead:
---------- Post added at 04:52 AM ---------- 6 hour anti-bump limit - Previous post was at 04:50 AM ----------
scared to kacau xtractor manifold as gasket bocor laa/temp naik laa etc..wohh:banghead:(genting kanjo reveals alll!
---------- Post added at 04:56 AM ---------- 6 hour anti-bump limit - Previous post was at 04:52 AM ----------
my budget around5/6k (b4 i found out the flaw in all the turboz engine mod?(rather stick to N.A !..yes is waste of money but i take my chances on changing gearbox then changing engines !at thr end of the day my seefuus its all about temperature!:banghead:
do full FTO 200hp engine swap la...with manual gearbox :listen: sure :driver::driver::driver:
u mean the reflector? not neccessary need to buy together with bonnet. keep searching around bro, klang plenty
