Pc Network Cable Can Use As Rca?
abflug34
DEAR ICE SIFU
i've read somewhere........i wanna know that if the networking pc cable can be use as RCA cable ??is it realible?how about noise?? thanx
any cable with 2 or more wires in it can make into rca cable, the issue is how good is the sound and how bad is the noise....
http://www.gr8tunes.net/forum/showthread.php?t=3462
this might help..
abflug34 said:
DEAR ICE SIFU
Yes you can. I had used it before and I changed to streetwires. Not because it sound bad but it looks fugly.
that's mean the sound was great?
just the appearance only not so good..
thanx great info..
networking cable is usually UTP.. -> twisted pair...
Normally you would only use twisted pair in a balanced transmission system. Because the cables are twisted in such a way, and couples with the inverted phase of the signal , the generated EMF will cancel each other out. also, the twisted configuration ensures that any noise induced into the cable does so equally in both cables so that it can be "cleaned up" at the balanced input stage.
normally, there will not be any advantage to use twisted pair cables in unbalanced systems, it would be worse still if the twisted pair has no outer grounding layer, as it will be susceptible to noise...
unbalanced system -> go for normal co-axial cable with a ground sheath
if no choice -> get one with proper shielding
balanced system -> ok to go for twisted pair
they sound clean n clear, easily beats tose rm1xx cable...
try n use it on tweeter....:) 1 pair (1 twisted pair only) is enof, but the thing is they r hard, break easily...
