Parts Guide With Part Number
crazykatak
Hi there.
As a fellow driver, I'd like to list down some useful info on parts.
I purchased all these parts at Proton Parts Center, Glenmarie.
Details such as part number, name, quantity used per car will be provided.
Feel free to add.
Clutch cover (1pc) P/No: PW810397
Clutch disc (1pc) P/No: PW810394
Bearing, clutch release (1pc) P/No: MD749998
Clutch cover bolts (6pcs) P/No: MF241251
Flywheel bolts (5pcs) P/No: PW811037
Bracket assy for gear cables (1pc) P/No: MD771555
Brake fluid DOT4 (for clutch fluid) P/No: BF500XT
Gear speed sensor (1pc) P/No: MD757531
Speed sensor (1pc) P/No: MD757541
Clutch master cylinder pin (1pc) P/No: MB858800
MT, assy transmission (A/T) (1pc) P/No: PW828452
Water pump kit ( with gasket ) PW811592N2-K
Timing belt kit (oil seal camshaft 2pcs, oil seal crankshaft 1pc, timing belt 1pc, timing belt tensioner bearing 1pc) PW898044
Bolt-M10X1.25X55-Special (1pc; for timing belt tensioner bearing) PW811696
Bolt-Sprocket-camshaft (1pc; 1 engine uses 2pcs) PW811705
Top mark (1pc; Rear bonnet garnish Proton emblem) PW846345
let me put all the parts list.. :biggrin:
kopi pasta from somewhere i dont remember where while browsing.. with price also :rolleyes:
PROTON Satria 3 Dr Hatch 1.6 Neo CPS (A) [02/09-]
No Description Part No Price
1 [Assy (Sanden)] A/C Blower Unit PW869611 1,350.00
2 [Assy (Patco)] -- as above -- PW869612 458.18
3 [Sanden] A/C Compressor PW810641 1,163.42
4 [Sanden] A/C Compressor Clutch PW893251 317.28
5 [Patco (Assy with Rec. Drier)] A/C Condenser PW823623 629.12
6 [Sanden (Assy with Rec. Drier)] -- as above -- PW823864 610.91
7 [Patco-T.Gray/Graphite(Hi-Line)] A/C Control Assembly PW869465-X0512 1,072.15
8 [Sanden-T.Gray/Graphi.(Hi-Line)] -- as above -- PW869469-X0512 789.09
9 [Sanden (Assy) - Hi-Line] A/C Evaporator PW851962 1,458.33
10 [Patco (Assy) - Hi-Line] -- as above -- PW869646 1,448.36
11 [Cooling coil (Patco)] -- as above -- PW891418 624.56
12 [Cooling coil (Sanden)] -- as above -- PW892438 666.48
13 [Patco] A/C Evaporator Filter PW853013 68.75
14 [Sanden] -- as above -- PW892420 91.02
15 [Sanden - Blower] A/C Fan Motor PW892468 458.18
16 [Patco - Blower] -- as above -- PW950164 472.35
17 [Patco - Suction] A/C Hose PW823596 106.78
18 [Sanden - Suction] -- as above -- PW855898 254.55
19 [Sanden - Discharge] -- as above -- PW855899 147.64
20 [Patco - Discharge] -- as above -- PW868619 128.09
21 [All] A/C Interior Sensor PW869632 159.55
22 [Patco - Suction pipe] A/C Pipes Front Firewall PW868229 196.27
23 [Sanden - Suction pipe] -- as above -- PW869471 211.27
24 [Patco - Liquid pipe] A/C Pipes Headlamp Panel LH PW868600 112.77
25 [Sanden - Liquid pipe] -- as above -- PW869474 178.18
26 [Sanden] A/C Receiver Drier PW892424 93.37
27 [Patco] -- as above -- PW950172 111.53
28 [All] A/C Relay PW539912 12.11
29 [All] A/C Solar Sensor PW869633 172.14
30 [All] ABS Pump Modulator PW891998 5,409.53
31 [All] ABS Pump Modulator Bracket PW868995 27.36
32 [All] ABS Sensor Front LH PW823607 538.00
33 [All] ABS Sensor Front RH PW823608 538.00
34 [All] ABS Sensor Rear LH PW820287 549.70
35 [All] ABS Sensor Rear RH PW820288 549.70
36 [All] Aerial Base PW869627 95.71
37 [Feeder cable A] Aerial Cable PW869625 34.79
38 [Feeder cable B] -- as above -- PW869626 29.56
39 [All] Aerial Pole PW869628 31.05
40 [Upper (Patco)] Air Cond Blower Cover PW891428 54.81
41 [Case (Sanden)] -- as above -- PW892455 69.84
42 [Lower (Patco)] -- as above -- PW950159 33.69
43 [Air Filter to Throttle Body] Air Filter Duct PW812309 57.54
44 [All] Air Filter Element PW811941 23.71
45 [All] Air Filter Lower Case PW812308 42.59
46 [All] Air Filter Pick Up Pipe PW812297 193.01
47 [All] Air Filter Upper Case PW812307 49.00
48 [All] Airbag Drivers side PW828582 957.01
49 [All] Airbag ECU PW852542 606.84
50 [All] Airbag Passenger Side PW842215 1,226.18
51 [4 way (11mm connect.)] Airbag Rotary Coupling PW854143 214.49
52 [6 way (11mm connect.)] -- as above -- PW854144 196.96
53 [All] Alarm Horn PW851846 80.16
54 [All] Alarm Kit PW869653 2,836.61
55 [All] Alarm Module PW869576 2,424.71
56 [All] Alternator PW810715 791.04
57 [All] Alternator Pulley PW892002 232.13
58 [Alternator/AC/PStrg/Water pump] Auxiliary Drive Belt PW811496 69.54
59 [Tailgate] Badge PW841500 32.99
60 [Grille - Monochrome] -- as above -- PW846590 22.86
61 [Grille - Gold Plated] -- as above -- PW867721-O0009 35.26
62 [CPS] Badge Boot Lid PW835505 21.38
63 [1.6] Badge Boot/Tailgate PW835340 18.69
64 [HANDLING BY LOTUS] Badge Tailgate PW564445 62.42
65 [Satria] -- as above -- PW835327 45.82
66 [Neo] -- as above -- PW837174 96.78
67 [All] Battery PW852609 271.67
68 [Maintenance Free(DIN45R)] -- as above -- PW852992 346.32
69 [All] Battery Tray PW869343 68.47
70 [All] Bodyside Weatherstrip LH PW867017 70.70
71 [All] Bodyside Weatherstrip RH PW867018 70.70
72 [All] Bonnet PW867118X1ED 609.52
73 [All] Bonnet Hinge LH PW867123 28.87
74 [All] Bonnet Hinge RH PW867124 28.87
75 [All] Bonnet Insulation PW869412 88.70
76 [All] Bonnet Insulation Clip MU481187 3.97
77 [All] Bonnet Latch Stud Plate PW867293 16.08
78 [All] Bonnet Lock PW869127 29.02
79 [All] Bonnet Pull Cable PW867131 21.24
80 [All] Bonnet Release Handle PW863814 4.12
81 [All] Bonnet Stand PW867126 16.50
82 [All] Bonnet Stand Retainer MB889049 2.42
83 [All] Bonnet Striker PW869128 36.65
84 [Front] Bonnet Weatherstrip PW834811 9.34
85 [All] Bonnet Weatherstrip Rear PW867604 24.64
86 [All] Boot Extractor Vent PW869314 17.71
87 [All] Boot Floor PW867383X1ED 656.82
88 [All] Brake Booster PW869395 424.59
89 [All] Brake Booster Hose PW868206 88.71
90 [All] Brake Caliper Front LH PW891167 788.02
91 [All] Brake Caliper Front Pad Set PW891172 283.95
92 [All] Brake Caliper Front RH PW891168 788.02
93 [All] Brake Caliper Front Support LH PW891169 668.89
94 [All] Brake Caliper Front Support RH PW891170 668.89
95 [All] Brake Caliper LHR PW891173 1,334.98
96 [All] Brake Caliper RHR PW891174 1,334.98
97 [All] Brake Disc Front PW868976 299.78
98 [All] Brake Disc Rear PW823053 225.37
99 [All] Brake Flexible Hose Front LH PW823909 49.60
100 [All] Brake Flexible Hose Front RH PW823910 49.60
101 [All] Brake Flexible Hose Rear LH PW824404 55.35
102 [All] Brake Flexible Hose Rear RH PW824405 55.35
103 [ABS] Brake Master Cylinder Assembly PW869425 258.32
104 [All] Brake Master Cylinder Container PW892588 79.91
105 [All] Brake Master Cylinder Container Cap PW891516 23.89
106 [Frt. to Rr.(ABS)] Brake Pipes Chassis/Floor Front LH PW868685 31.11
107 [Frt. to Rr.(ABS)] Brake Pipes Chassis/Floor Front RH PW868686 24.28
108 [All] Brake Proportioning Valve PW823699 132.24
109 [All] Brake Rear Pad Set PW891182 254.46
110 [All] Bumper Front Bracket LH PW869255 5.41
111 [All] Bumper Front Bracket RH PW869256 5.41
112 [All] Bumper Front Cover PW839231 1,571.22
113 [Tow Eye cover] Bumper Front Fixings LH PW839230 8.81
114 [Centre] Bumper Front Lower Grille PW839229 246.13
115 [All] Bumper Front Lower Grille LH PW839232 93.93
116 [All] Bumper Front Lower Grille RH PW839233 93.93
117 [All] Bumper Front Reinforcement PW867641 [C] 210.00 N
118 [All] -- as above -- PW867641 294.96
119 [All] Bumper Rear Bracket LH PW869257 4.79
120 [All] Bumper Rear Bracket RH PW869258 4.79
121 [All] Bumper Rear Cover PW839227P 1,576.54
122 [Tow Eye cover] Bumper Rear Fixings LH PW839225P 8.81
123 [Lower] Bumper Rear Grille PW839226 223.58
124 [All] Bumper Rear Reinforcement PW867645 227.64
125 [RH] Bumper Rear Sensor PW856088 45.45
126 [LH] -- as above -- PW856089 45.45
127 [All] Bumper Reflector LHR PW868611 40.52
128 [All] Bumper Reflector RHR PW868612 40.52
129 [All] C.V. Boot Kit (Outer) PW550189 185.57
130 [Outer] C.V. Joint PW890546 482.68
131 [Inner] -- as above -- PW890548 482.68
132 [All] Cable Gear Selector PW820054 78.35
133 [All] Cable Handbrake LH PW868490 29.61
134 [All] Cable Handbrake RH PW868489 30.96
135 [Exhaust] Camshaft PW892052 1,679.07
136 [Inlet] -- as above -- PW892053 1,679.07
137 [All] Carpet Floor Complete PW867818-C0025 547.19
138 [All] Centre Console PW867893-P0053 99.57
139 [LH (A/con. control switches)] Centre Console Front Section PW842206-P0053 25.14
140 [RH (A/con. control switches)] -- as above -- PW842207-P0053 25.14
141 [Tempest Gray] Centre Pillar Upper Trim LH PW843107-P0050 64.42
142 [Beige] -- as above -- PW869007-H0009 98.47
143 [Tempest Gray] Centre Pillar Upper Trim RH PW843108-P0050 64.42
144 [Beige] -- as above -- PW869008-H0009 98.47
145 [All] Chassis Member Front Assembly LH PW867053X2-2ED 649.89
146 [All] Chassis Member Front Assembly RH PW867054X2-2ED 665.89
147 [All] Chassis Member Rear Assembly LH PW867325X3ED 650.20
148 [All] Chassis Member Rear Assembly RH PW867326X3ED 650.20
149 [Frt. & Rr. Bumpers] Clips MR200300 4.42
150 [All] Clock PW868662 99.63
151 [All] Connecting Rod PW811022 137.41
152 [All] Connecting Rod Bearing PW811021 10.87
153 [Frt. of Console Ctr.] Console Centre Cover PW842209-P0053 9.01
154 [APM] Cooling Fan Cover PW891121 [C] 105.00 N
155 [APM] -- as above -- PW891121 109.16
156 [Denso] -- as above -- PW891968 109.16
157 [Assembly (APM)] Cooling Fan Motor PW891123 [C] 300.00 N
158 [Assembly (APM)] -- as above -- PW891123 865.45
159 [Denso] -- as above -- PW891978 420.15
160 [All] Cover Rr. - A/T MD763204 2,203.33
161 [All] Cover Seat Back Front LH PW894344 462.15
162 [All] Cover Seat Back Front RH PW894345 462.15
163 [All] Cover Seat Back Rear LH PW894348 355.10
164 [All] Cover Seat Back Rear RH PW894349 512.33
165 [All] Cover Seat Cushion Front LH PW894346 111.53
166 [All] Cover Seat Cushion Front RH PW894347 358.77
167 [All] Cover Seat Cushion Rear PW894339 772.22
168 [All] Cowl Panel PW867082X2-2ED 721.95
169 [Assembly] Cowl Panel Grille PW867600-P0034 92.17
170 [All] Crankshaft PW811005 2,329.85
171 [All] Crankshaft Bearing PW811440 28.44
172 [2pcs./pack (No:1)] -- as above -- PW892027N 16.87
173 [2pcs./pack (No:2)] -- as above -- PW892028N 16.87
174 [2pcs./pack (No:3)] -- as above -- PW892029N 16.87
175 [2pcs./pack (No:4)] -- as above -- PW892030N 16.87
176 [2pcs./pack (No:5)] -- as above -- PW892031N 16.87
177 [All] Crossmember Boot Floor Centre PW867479X1ED 435.59
178 [Switch] Cruise Control Actuator PW851935 45.37
179 [Tailgate] Cushion PW558207 0.70
180 [All] Cylinder Head PW810961X1 2,772.32
181 [Tempest Gray] Dashboard Panel PW869862-P0053 776.44
182 [All] Dashboard Panel Centre Panel PW842193-D0030 115.50
183 [Tempest Gray - with A/Bag] Dashboard Panel Crash Pad PW842263-P0053 709.24
184 [Tempest Gray] Dashboard Panel End Cover PW867876-P0053 49.80
185 [All] Dashboard Panel Lower Dash Panel RH PW843030-P0053 240.76
186 [All] Dashboard Panel Trim LH PW842194-D0030 141.54
187 [All] Dashboard Panel Trim RH PW842192-D0030 126.43
188 [All] Dashboard Vents PW867868-X0803 103.58
189 [Dashboard upper] Demister Vent PW867866 118.06
190 [All] Door Front Aperture Weatherstrip LH PW867019 50.18
191 [All] Door Front Aperture Weatherstrip RH PW867020 50.18
192 [All] Door Front Check Strap PW869715 55.69
193 [All] Door Front Hinge LH PW869193 73.99
194 [All] Door Front Hinge RH PW869194 73.99
195 [All] Door Front LH PW869247X1ED 1,254.52
196 [All] Door Front Lower Seal LH PW867021 22.16
197 [All] Door Front Lower Seal RH PW867022 22.16
198 [All] Door Front RH PW869248X1ED 1,254.52
199 [All] Door Glass Front Window LH PW836623 84.96
200 [All] Door Glass Front Window RH PW836624 84.96
201 [Rr. of Door] Door Glass Run Channel Rear Front LH PW867749 37.01
202 [Rr. of Door] Door Glass Run Channel Rear Front RH PW867750 37.01
203 [All] Door Glass Run Felt Front LH PW835211-P0034 86.52
204 [All] Door Glass Run Felt Front RH PW835212-P0034 86.52
205 [All] Door Glass Weatherstrip Inner Front LH PW867025 34.90
206 [All] Door Glass Weatherstrip Inner Front RH PW867026 34.90
207 [All] Door Glass Weatherstrip Outer Front LH PW867023 49.94
208 [All] Door Glass Weatherstrip Outer Front RH PW867024 49.94
209 [Tempest Gray] Door Handle Inner Release PW832417-D0025 60.30
210 [Handle Cap] Door Handle Outer Bezel Front LH PW832452 11.49
211 [Handle Cap] Door Handle Outer Bezel Front RH PW832451 12.60
212 [All] Door Handle Outer Release PW832401 24.64
213 [Tempest Gray] Door Lock Inner Button PW835345 2.15
214 [All] Door Lock LH PW896118 223.03
215 [All] Door Lock RH PW896119 223.03
216 [All] Door Lock Striker PW869580 27.88
217 [All] Door Mirror Glass LH PW890557 23.05
218 [All] Door Mirror Glass RH PW891216 23.05
219 [Electric] Door Mirror LH PW867659 194.63
220 [Electric] Door Mirror RH PW867660 194.63
221 [Adapter Plate RHF] Door Outer Release Handle Base PW869056 52.44
222 [Adapter Plate LHF] -- as above -- PW869058 32.50
223 [All] Door Pull Inner LH PW867813-D0030 51.47
224 [All] Door Pull Inner RH PW867814-D0030 51.47
225 [All] Door Regulator Motor Front LH PW891144N 106.52
226 [All] Door Regulator Motor Front RH PW891143N 106.52
227 [All] Door Trim Board Finisher LH PW869021-X0805 555.58
228 [All] Door Trim Board Finisher RH PW869022-X0805 555.58
229 [All] Door Window Regulator Front LH PW891225 36.96
230 [All] Door Window Regulator Front RH PW891224 36.96
231 [All] Dr Mirror Inner Trim Cover LH PW867825-P0034 22.32
232 [All] Dr Mirror Inner Trim Cover RH PW867826-P0034 22.32
233 [All] Driveshaft Boot Kit (Inner) PW890555 197.91
234 [All] Driveshaft Front LH PW812125 727.68
235 [All] Driveshaft Front RH PW812124 764.17
236 [All] ECU Automatic Transmission 8631A762 2,756.39
237 [All] ECU Door CDL PW869677 37.48
238 [All] ECU Engine PW810508 849.18
239 [All] ECU Engine ECU Mounting Bracket PW869356 17.92
240 [All] ECU Reverse Sensor PW856078 65.53
241 [RH] Electric Window Control Panel PW868660 52.12
242 [Assembly] Engine S4PH-1-CSA 11,890.66
243 [All] Engine (Short Motor) PW892021 8,213.47
244 [Inlet Manifold Bracket] Engine Bay Brace PW811671 8.47
245 [All] Engine Block PW892054 4,665.56
246 [Top outer] Engine Cover Trim PW810411 128.61
247 [Inner (Small)] -- as above -- PW810820 23.89
248 [All] Engine Exhaust Valve PW810805 87.31
249 [All] Engine Gasket Top Set PW898013 504.53
250 [All] Engine Inlet Manifold PW810758 968.03
251 [All] Engine Inlet Manifold Gasket PW810787 59.84
252 [All] Engine Lower Splash Shield LH PW868568 31.65
253 [All] Engine Lower Splash Shield RH PW868569 31.65
254 [Torque reaction mounting] Engine Mounting Bracket PW562115 41.06
255 [Front] -- as above -- PW810749 96.12
256 [All] Engine Mounting Bracket RH PW825315 353.85
257 [Transmission] Engine Mounting LH PW828452 23.16
258 [All] Engine Mounting RH PW826518 147.34
259 [All] Engine Oil Sump PW812263 632.19
260 [All] Engine Overhaul Gasket PW898012 567.42
261 [All] Engine Partition Panel PW867361X4ED 722.50
262 [Crankshaft] Engine Pulley(s) PW811261 217.00
263 [All] Engine Torque Reaction Rod Mounting PW868421 77.88
264 [All] Exhaust Catalytic Converter PW810651 1,619.64
265 [All] Exhaust Heat Shield Fuel Tank PW823173 59.58
266 [All] Exhaust Manifold PW810904 327.59
267 [All] Exhaust Manifold Cover PW811673 90.21
268 [Between Ex.Manifold & Cat.Conv] Exhaust Manifold Gasket PW811658 23.82
269 [All] -- as above -- PW811743 12.34
270 [Frt., Ctr. & Rr. of Frt.pipe] Exhaust Mounting PW820443 6.97
271 [at Silencer] Exhaust Mounting Rear PW822939 4.30
272 [All] Exhaust Pipe Front PW868403 511.85
273 [All] Exhaust Silencer PW868462 658.00
274 [Denso] Fan Blade (Radiator) PW891979 86.45
275 [Bracket] Fender Front Inner Support LH PW867313ED 61.02
276 [Bracket] Fender Front Inner Support RH PW867314 61.02
277 [All] Fender Front Inner Wheel House LH PW867039X3ED 574.23
278 [All] Fender Front Inner Wheel House RH PW867040X4ED 574.23
279 [All] Fender Front LH PW839207X1ED 134.75
280 [All] Fender Front Liner LH PW867613 59.90
281 [All] Fender Front Liner RH PW867614 59.90
282 [All] Fender Front RH PW839208X1ED 134.75
283 [All] Fender Signal Lamp PW850533 [C] 16.00 N
284 [All] -- as above -- PW850533 40.67
285 [All] Flasher Relay PW546916 21.96
286 [Centre Rr.] Floor Mat PW842345-C0026 19.30
287 [All] Floor Pan Crossmember Center PW867544X1ED 466.09
288 [All] Floor Pan Front PW867401X3ED 985.23
289 [All] Floormat Front LH PW842341-C0026 38.83
290 [All] Floormat Front RH PW842342-X0218 45.83
291 [All] Floormat Rear LH PW842343-C0026 24.14
292 [All] Floormat Rear RH PW842344-C0026 24.14
293 [All] Fly Wheel PW811013 249.96
294 [LH] Fog Lamp Mounting Bracket PW857063 0.00
295 [RH] -- as above -- PW857064 0.00
296 [All] Foot Rest PW842365 23.44
297 [All] Front Panel Assembly PW867079X2ED 466.41
298 [at Frt. Panel Upper] Front Panel Upper Cushion PW830663 1.31
299 [All] Front Pillar Inner Lower LH PW867281X2ED 103.25
300 [All] Front Pillar Inner Lower RH PW867282X2ED 103.25
301 [All] Front Pillar Outer LH PW867213X1AED 236.80
302 [All] Front Pillar Outer RH PW867214X1AED 236.80
303 [All] Front Pillar Reinforcement Lower LH PW867305X1ED 125.89
304 [All] Front Pillar Reinforcement Lower RH PW867306X1ED 125.89
305 [Tempest Gray] Front Pillar Upper Trim LH PW843105-P0050 61.71
306 [Tempest Gray] Front Pillar Upper Trim RH PW843106-P0050 61.71
307 [All] Fuel Charcoal Filter PW823064 81.91
308 [All] Fuel Delivery Pipe PW811776 17.04
309 [All] Fuel Filler Cap PW820221 38.14
310 [All] Fuel Filler Flap PW869290-X0346 98.25
311 [All] Fuel Filler Flap Release Cable PW867134 12.06
312 [Tempest Gray] Fuel Filler Flap Release Handle PW532169-P0053 16.19
313 [All] Fuel Filler Housing PW867210X1ED 0.00
314 [All] Fuel Filler Lock PW867988 16.08
315 [All] Fuel Filter PW823181 37.58
316 [All] Fuel Injector PW810765 145.54
317 [All] Fuel Pressure Regulator Assy PW811654 97.62
318 [All] Fuel Return Pipe PW828521 96.14
319 [All] Fuel Supply Pipe PW868470 62.11
320 [All] Fuel Tank PW823191 752.13
321 [All] Fuel Tank Filler Tube PW868546 144.28
322 [All] Fuel Tank Float & Pump Unit PW823172 412.90
323 [All] Fuel Tank Strap LH PW891612 37.71
324 [All] Fuel Tank Strap RH PW891614 38.52
325 [All] Fuel Vent Pipe PW812291 38.13
326 [All] Gasket Cylinder Head PW811553 133.38
327 [All] Gasket Rocker Cover PW810825 38.90
328 [Assembly] Gear Shift Lever PW868527-X0840 349.15
329 [All] -- as above -- PW893242 129.48
330 [Shift Lever Indicator] Gear Shift Lever Gaiter PW886136 107.22
331 [All] Gear Shift Lever Knob PW825067-X0840 174.10
332 [All] Gear Shift Lever Lower Bracket PW821101 94.85
333 [All] Gear Shift Lever Surround PW867901-X0472 61.79
334 [All] Glove Box Lid Lock PW842204-P0053 75.27
335 [All] Glove Compartment Assembly PW867867-P0053 214.24
336 [All] Grille Front PW839228 257.82
337 [All] Handbrake Lever PW869416-X0798 130.32
338 [All] Handbrake Lever Boot PW869034-P0053 4.67
339 [All] Header Rail PW867249ED 113.50
340 [All] Headlamp Assy LH PW868603 368.02
341 [All] Headlamp Assy RH PW868604 368.02
342 [Turn signal] Headlamp Bulb PS180071 9.40
343 [H4] -- as above -- PW501690 24.74
344 [All] Headrest Assembly Front PW867947-X0790 160.67
345 [All] Headrest Assembly Rear PW867946-X0790 168.39
346 [All] High Level/Third Brake Light PW868610 65.53
347 [Set] Horn PW869679 77.71
348 [All] Ignition Coil PW811201 197.34
349 [All] Inlet Valve PW810852 27.26
350 [All] Instrument Cluster Surround PW842189 44.43
351 [Below Dashboard(Cabin)] Insulation Inner Bulkhead PW869014 164.95
352 [Engine Compartment] Insulation Outer Bulkhead PW868232 59.52
353 [All] Insulation Roof Panel PW868990 82.77
354 [All] Interior Lamp Lens PW891136 8.89
355 [ABS] Knuckle Arm Front LH PW868977 300.14
356 [ABS] Knuckle Arm Front RH PW868978 300.14
357 [Oxygen sensor] Lambda Sensor PW811631 244.50
358 [All] Lamp Assembly Rear Bulb Holder PW891688 32.95
359 [All] Lamp Assembly Rear LH PW868607 153.45
360 [All] Lamp Assembly Rear RH PW868608 153.45
361 [All] Lamp Fog Front LH PW869650 168.68
362 [All] Lamp Fog Front RH PW869651 168.68
363 [Light Gray] Lamp Interior PW835190-P0050 26.21
364 [All] Lamp Luggage Compartment PW851780 11.49
365 [All] Mirror Rear View PW840109-P0000 58.23
366 [All] Moulding Door Front Lower LH PW843773 165.53
367 [All] Moulding Door Front Lower RH PW843774 165.53
368 [All] Moulding Quarter Panel LH PW843775 76.31
369 [All] Moulding Quarter Panel RH PW843776 76.31
370 [All] Moulding Roof LH PW867647-P0034 50.18
371 [All] Moulding Roof RH PW867648-P0034 50.18
372 [Meters complete] Multi Function Display Unit PW869589 497.65
373 [RH] Number Plate Lamp/Lamps PW850534 17.06
374 [LH] -- as above -- PW850819 17.06
375 [Transmission to Radiator] Oil Cooler Pipes MD761328 116.03
376 [All] Oil Filter PW811577 12.22
377 [All] Oil Pump PW810803 837.87
378 [All] Oil Sump Strainer PW812266 30.52
379 [Tempest Gray] Parcel Shelf PW867952-X0473 250.91
380 [All] PAS Container PW821258 41.80
381 [All] PAS Container Cap PW821257 11.64
382 [Tube] PAS Oil Cooler PW868310 49.06
383 [All] PAS Pump PW811427 664.62
384 [Cooler Tube to Reservoir] PAS Return Hose PW869266 11.44
385 [at Steering rack] -- as above -- PW869274 70.96
386 [Reservoir To Pump] PAS Supply Hose PW869269 14.35
387 [at Steering rack] -- as above -- PW869276 157.94
388 [All] Pedal Brake PW868836 408.53
389 [Brake & Throttle] Pedal Support Bracket PW820773 61.12
390 [All] Pedal Throttle PW828282 270.21
391 [with Pin] Piston PW893443 66.57
392 [All] Piston Ring Set PW891185 125.36
393 [All] Position Sensor Camshaft PW811314 147.94
394 [All] Position Sensor Crankshaft PW810614 133.92
395 [Front (Tempest Gray)] Quarter Inner Trim Lower LH PW843111-P0053 172.65
396 [Front (Tempest Gray)] Quarter Inner Trim Lower RH PW843112-P0053 172.65
397 [All] Quarter Panel Inner LH PW867189X1ED 404.29
398 [All] Quarter Panel Inner Lower Extension LH PW867245X1ED 192.22
399 [All] Quarter Panel Inner Lower Extension RH PW867246X1ED 192.22
400 [All] Quarter Panel Inner Reinforcement Upper LH PW869101X1ED 88.65
401 [All] Quarter Panel Inner Reinforcement Upper RH PW869102X1ED 88.65
402 [All] Quarter Panel Inner RH PW867190X1ED 404.29
403 [with Moulding Hole] Quarter Panel LH PW867215X1BED 1,169.14
404 [All] Quarter Panel Liner LH PW867607 36.49
405 [All] Quarter Panel Liner RH PW867608 36.49
406 [with Moulding Hole] Quarter Panel RH PW867216X1BED 1,169.14
407 [All] Quarter Panel Upper Extension LH PW867219X1ED 33.58
408 [All] Quarter Panel Upper Extension RH PW867220X1ED 33.58
409 [Tempest Gray] Quarter Pillar Rear Upper Trim LH PW843109-P0050 78.27
410 [Beige] -- as above -- PW867853-H0009 162.31
411 [Tempest Gray] Quarter Pillar Rear Upper Trim RH PW843110-P0050 78.27
412 [Beige] -- as above -- PW867854-H0009 162.31
413 [Tempest Gray] Quarter Trim Rear Lower LH PW843113-P0053 138.60
414 [Tempest Gray] Quarter Trim Rear Lower RH PW843114-P0053 138.60
415 [APM] Radiator PW822437 1,050.85
416 [Denso] -- as above -- PW826692 650.66
417 [All] Radiator Bottom Hose PW868502 33.98
418 [Denso] Radiator Cap MB660667 40.21
419 [APM] -- as above -- PW510892 24.13
420 [All] Radiator Expansion Tank PW824406 57.90
421 [All] Radiator Overflow Hose PW868553 3.06
422 [Upper] Radiator Support Bracket LH PW868499 11.55
423 [Upper] Radiator Support Bracket RH PW868500 11.55
424 [All] Radiator Top Hose PW868496 14.23
425 [All] Radio/CD Player PW869526-D0030 1,586.01
426 [All] Rear Lamp Lens LH PW891685 123.84
427 [All] Rear Lamp Lens RH PW891686 123.84
428 [All] Rear Lamp Panel Interior Trim LH PW869421-P0053 9.65
429 [All] Rear Lamp Panel Interior Trim RH PW869422-P0053 9.65
430 [All] Rear Panel Assembly PW867150X1ED 286.20
431 [Tempest Gray] Rear Panel Inner Trim PW868170-P0053 79.78
432 [All] Rear Suspension Arm Bush PW868267 12.22
433 [All] Rear Trailing Arm Bush PW551025 28.73
434 [Engine Room] Relay Box PW892758 6.42
435 [Engine Room - Top] Relay Box Cover PW892757 11.83
436 [All] Rocker Cover PW810824 409.79
437 [All] Rocker Cover Cap PW811850 35.74
438 [Beige] Roof Grip Handle Roof Front LH PW841269-P0032 12.22
439 [Tempest Gray] -- as above -- PW841269-P0050 11.83
440 [Beige] Roof Grip Handle Roof Rear LH PW841271-P0032 14.38
441 [Tempest Gray] -- as above -- PW841271-P0050 13.93
442 [Beige] Roof Grip Handle Roof Rear RH PW841272-P0032 14.38
443 [Tempest Gray] -- as above -- PW841272-P0050 13.93
444 [All] Roof Panel PW867239ED 341.55
445 [All] Roof Panel Centre Bow PW867255ED 94.34
446 [All] Roof Panel Rear Member PW867250X1ED 85.95
447 [Tempest Gray] Rooflining PW867930-H0015 357.84
448 [Beige] -- as above -- PW868185-H0009 357.84
449 [All] Rooflining Retainer Clip Rear MB643847 0.00
450 [Beige] Runningboard Panel Inner Trim LH PW868763-P0029 80.93
451 [Tempest Gray] -- as above -- PW868763-P0053 80.93
452 [Beige] Runningboard Panel Inner Trim RH PW868764-P0029 80.93
453 [Tempest Gray] -- as above -- PW868764-P0053 80.93
454 [All] Runningboard Panel LH PW867213X1CED 420.39
455 [All] Runningboard Panel Reinforcement LH PW867183X1ED 75.89
456 [All] Runningboard Panel Reinforcement RH PW867184X1ED 75.89
457 [All] Runningboard Panel RH PW867214X1CED 420.39
458 [Tempest Gray] Runningboard Panel Tread Plate LH PW867835-D0025 117.84
459 [Tempest Gray] Runningboard Panel Tread Plate RH PW867836-D0025 117.84
460 [LH - Recliner] Seat Adjuster Handle Front PW893195 2.74
461 [RH - Recliner] -- as above -- PW893196 2.74
462 [RH - Height Adj.] -- as above -- PW893225 2.83
463 [All] Seat Back Assembly Front LH PW894340 1,598.29
464 [All] Seat Back Assembly Front RH PW894341 1,679.75
465 [All] Seat Back Assembly Rear LH PW867941-X0789 678.29
466 [All] Seat Back Assembly Rear RH PW867942-X0789 1,081.99
467 [All] Seat Back Latch Rear LH PW893214 39.89
468 [All] Seat Back Latch Rear RH PW893213 39.89
469 [Knob] Seat Back Release Handle PW891667 17.09
470 [All] Seat Belt Front Reel LH PW842385-X0451 473.29
471 [All] Seat Belt Front Reel RH PW842386-X0451 473.29
472 [All] Seat Belt Rear Centre Reel PW843099-X0451 137.12
473 [All] Seat Belt Rear Lap Buckle PW843100-X0451 27.79
474 [All] Seat Belt Rear Reel LH PW842397-X0451 156.20
475 [All] Seat Belt Rear Reel RH PW842398-X0451 156.20
476 [All] Seat Belt Rear Stalk RH PW842396-X0451 27.79
477 [All] Seat Belt Stalk Front PW841129-X0451 28.69
478 [All] Seat Cushion Assembly Front LH PW894342 523.91
479 [All] Seat Cushion Assembly Front RH PW894343 523.91
480 [Assembly] Seat Cushion Rear PW867945-X0789 1,106.13
481 [Inner] Seat Rail Trim Front LH PW893227 25.96
482 [Outer] -- as above -- PW893230 28.73
483 [Inner] Seat Rail Trim Front RH PW893226 25.96
484 [Outer] -- as above -- PW893228 28.87
485 [All] Seat Slider Assembly Front LH PW891631 761.99
486 [All] Seat Slider Assembly Front RH PW893211 858.01
487 [with ABS (APM)] Shock Absorber Front LH PW823883 154.95
488 [with ABS (APM)] Shock Absorber Front RH PW823884 154.95
489 [All] Shock Absorber Front Top Mount PW820608V1 112.09
490 [APM] Shock Absorber Rear PW868289 119.35
491 [All] Shock Absorber Rear Top Mount PW551179 15.05
492 [MSG] Side Glass LH PW867623-G0000 60.57
493 [MSG] Side Glass RH PW867624-G0000 60.57
494 [All] Spare Wheel Cover Board PW843115-C0028 170.88
495 [All] Spare Wheel Retainer PW822512 21.23
496 [BPR6EF-11] Spark Plug PW811750 9.50
497 [All] Spark Plug Cable Set PW810763 311.13
498 [All] Speaker Door PW869570 51.10
499 [LH (Tempest Gray)] Speaker Grille Rear PW869015-P0053 12.87
500 [RH (Tempest Gray)] -- as above -- PW869016-P0053 12.87
501 [All] Speaker Rear PW869550 48.48
502 [All] Spectacles Holder PW841766 19.57
503 [All] Spoiler Rear - Top PW839062 878.43
504 [All] Spoiler Runningboard Extension LH PW843781 824.99
505 [All] Spoiler Runningboard Extension RH PW843782 824.98
506 [All] Spoiler Wheel Arch Extension Front LH PW843777 447.11
507 [All] Spoiler Wheel Arch Extension Front RH PW843778 447.11
508 [All] Spoiler Wheel Arch Extension Rear LH PW843779 508.59
509 [All] Spoiler Wheel Arch Extension Rear RH PW843780 508.59
510 [All] Stabiliser Bar Bracket Front PW521637 8.89
511 [All] Stabiliser Bar Bracket Rear PW820865 3.98
512 [All] Stabiliser Bar Front PW868259 144.44
513 [All] Stabiliser Bar Front Link Rod PW868483 102.93
514 [All] Stabiliser Bar Rear PW868303 122.73
515 [All] Stabiliser Bar Rear Link Rod PW868294 92.64
516 [Front] Stabilizer Bar Bush PW820088V1 2.72
517 [Rear] -- as above -- PW868300 3.58
518 [All] Starter Motor PW811240 430.48
519 [Assembly] Steering Column PW868306 358.15
520 [All] Steering Column Cover Lower PW841654 15.62
521 [All] Steering Column Cover Upper PW844266-P0030 20.36
522 [All] Steering Column Lock PW831744-S 659.79
523 [All] Steering Column Lock Cylinder Assembly PW892730 291.41
524 [All] Steering Column Lower Joint PW891624 129.68
525 [Upper Joint] Steering Column Universal Joint PW891623 181.77
526 [All] Steering Rack/Box PAS PW868362 1,001.57
527 [All] Steering Tie Rod PW893356 106.35
528 [All] Steering Tie Rod End PW510186 92.94
529 [All] Steering Wheel PW920133 922.59
530 [All] Steering Wheel Switch PW869529 147.24
531 [Dr. frame rear] Sticker LHFD PW842929 15.72
532 [Dr. frame rear] Sticker RHFD PW842930 15.72
533 [Beige] Sun Visor LH PW869001-X0217 93.20
534 [Beige] Sun Visor RH PW869002-X0217 93.76
535 [All] Suspension Arm Front Bottom Ball Joint PW868258 52.27
536 [All] Suspension Arm Front LH PW869155 266.11
537 [All] Suspension Arm Front RH PW869156 266.11
538 [Control Link] Suspension Arm Rear Link Rod PW868415 156.39
539 [All] Suspension Arm Rear Lower LH PW869147 111.90
540 [All] Suspension Arm Rear Lower RH PW869148 111.90
541 [ABS] Suspension Arm Rear Trailing Arm LH PW868273 297.75
542 [ABS] Suspension Arm Rear Trailing Arm RH PW868274 297.75
543 [Upper Link] Suspension Arm Rear Upper PW868853 322.60
544 [All] Suspension Crossmember Front PW869131 790.08
545 [All] Suspension Spring Front PW868250 44.00
546 [All] Suspension Spring Rear PW825168 49.19
547 [All] Switch Brake Pedal PW822263V2 21.89
548 [All] Switch Dashboard Light Cluster PW868730-D0030 226.11
549 [LH] Switch Electric Window PW868661 22.22
550 [All] Switch Exterior Mirror PW853221 50.13
551 [Leveling] Switch Headlamp Adjusting PW851884-D0025 61.82
552 [LH] Switch Lamp Interior Door PW536010 7.32
553 [RH] -- as above -- PW539089 17.01
554 [For Lights (Delloyd)] Switch Steering Column LH PW891032 132.65
555 [For Lights (Rexar)] -- as above -- PW891452 98.16
556 [For Wipers (Rexar)] Switch Steering Column RH PW891450 104.46
557 [For Wipers (Delloyd)] -- as above -- PW892512 106.25
558 [Assembly (Tempest Gray)] Switches Steering Column PW852577-P0021 233.71
559 [All] Tailgate PW867108X1ED 1,236.77
560 [All] Tailgate Aperture Weatherstrip PW869126 57.99
561 [All] Tailgate Finisher PW867652 153.09
562 [All] Tailgate Hinge PW867417 24.06
563 [All] Tailgate Lock PW832567 85.48
564 [at Tailgate] Tailgate Mass Damper PW868141 3.81
565 [at Body] Tailgate Mass Damper LH PW869189 11.10
566 [at Body] Tailgate Mass Damper RH PW869190 11.07
567 [All] Tailgate Release Cable PW867116 13.61
568 [All] Tailgate Striker PW837714 18.25
569 [APM] Tailgate Support Strut PW848907 63.84
570 [Beige] Tailgate Trim Board Lower PW843597-P0029 137.68
571 [Tempest Gray] -- as above -- PW843597-P0053 137.68
572 [All] Thermostat PW811761 41.29
573 [All] Throttle Body PW810613 511.54
574 [All] Timing Belt PW811498 123.03
575 [All] Timing Belt Lower Cover PW811686 30.35
576 [Crankshaft] Timing Belt Sprocket PW811007 21.38
577 [Camshaft] -- as above -- PW811515 46.66
578 [All] Timing Belt Tensioner PW811497 143.54
579 [All] Timing Belt Upper Cover PW811685 29.65
580 [All] Torque Convertor MR477467 6,917.53
581 [All] Torque Convertor Housing MD756902 2,301.51
582 [All] Towing Eye Front PW822701 14.89
583 [F4A4B-1-N6Z] Transmission Assy (A) 2700A233 24,101.45
584 [All] Transmission Case (A) MR593510 5,856.08
585 [All] Transmission Mtng. Brkt.(A) PW812368 482.52
586 [All] Transmission Oil Cooler Hose PW820267 42.73
587 [All] Transmission Oil Pump Assy MR593521 1,672.62
588 [All] Transmission Sump MD758639 357.90
589 [All] Valve Body MR486682 5,869.42
590 [All] Vehicle Jack PW510979 81.79
591 [All] Vehicle Jack Lever PW510986 4.90
592 [All] Vehicle Tool Kit PW551468 68.04
593 [RH] Washer Jet Front PW869608 11.19
594 [LH] -- as above -- PW869609 11.71
595 [All] Washer Jet Rear PW869549 12.37
596 [All] Washer Pump Screen PW852773 33.69
597 [All] Washer Tank Windcreen Front PW893157 72.81
598 [All] Washer Tubing Front PW893154 13.53
599 [All] Washer Tubing Rear PW867985 17.68
600 [All] Water Pump PW811592N2 220.56
601 [All] Water Pump Pulley PW811599 114.62
602 [All] Water Pump Tensioner PW811826 408.55
603 [LH & RH same] Weather Sheeting Door Front PW867829 9.13
604 [All] Wheel Bearing Kit Front PW891104 98.24
605 [All] Wheel Centre PW825414-A0173 22.52
606 [All] Wheel Hub Front PW821560 221.65
607 [All] Wheel Hub Rear PW823106 181.50
608 [16X6.5JJ] Wheel Rim Alloy PW826680-A0173 328.57
609 [All] Wheel Rim Spare PW868512 495.13
610 [All] Windscreen Front PW836619 401.77
611 [Spacers] Windscreen Front Guides MB814151 6.91
612 [All] Windscreen Front Moulding Outer PW877731 108.84
613 [All] Windscreen Rear PW836626 148.93
614 [All] Windscreen Rear Moulding PW869495 13.37
615 [4pcs./veh.] Windscreen Rear Spacer PW867716 17.71
616 [All] Wiper Front Arm LH PW867703 59.30
617 [All] Wiper Front Arm RH PW867701 59.30
618 [All] Wiper Front Blade LH PW867725 33.93
619 [All] Wiper Front Blade RH PW867722 33.93
620 [All] Wiper Front Link Rod PW867705 102.25
621 [All] Wiper Front Motor PW867677 353.29
622 [All] Wiper Rear Arm PW867423 97.18
623 [All] Wiper Rear Blade PW867425 39.60
624 [All] Wiper Rear Motor PW867421 225.56
625 [All] Wiring Body PW856819 1,145.02
626 [All] Wiring Dashboard PW856767 999.22
627 [All] Wiring Door Front LH PW853049 51.89
628 [All] Wiring Door Front RH PW853045 56.11
629 [All] Wiring Engine PW856815 1,065.11
630 [All] Wiring Engine Compartment PW853152 476.03
631 [Valve body] Wiring Front Auto Gearbox MR528943 380.85
632 [All] Wiring Front Battery Tray LH PW856816 433.11
633 [All] Wiring Front Panel PW856818 1,109.99
634 [All] Wiring Rear PW853043 67.33
635 [All] Wiring Rear Tailgate Upper PW853039 52.14
