paint the drum brake & front calipers
wanzer
Hello all,
I am thinking of painting my drum brakes & front calipers.
Any of you done it before? I just want to know:
a) do we need need special heat resistant paint?
b) any spray paint shop can do it?
c) any problems with heat dissipation?
d) any of u done it? how much? where?
Appreciate your feedback
wanzer said:
Hello all,
I know some used rims shop do it for you less than RM10. If you buy rims from there, it will be FOC. :D
Location at Berapit (B.Mertajam).
Any spray paint will do lar....no worry.....:D and it doesn't effect your braking result.
wanzer said:
Hello all,
browse around in the DIY section.. topic covered already i think..
recommend that u use heat resistant paint.. remove ur wheels.. get a paint brush and paint.. easier.
i sprayed my calipers using normal aerosol sprays...
i even sprayed my engine head using them...
no problem using them...
din c any bubbling or watsoeva...
u'l neva know, till u try it yrself....
partyJOE: As i know we need to b extra carefully went gonna to spray the caliper, coz this might affect the braking performance, is that true?
hey bro, wat brand of the sprays u used?
careful in the sense u have to cover all other areas properly....
i use 1' masking tape... fast n easy to use...
brand name have to check..
i'l try 2 post sum pics 2moro....(",)
