Overclocking Help
eterna22
this is what im running now....
Intel Celeron 1.7GHz
MSI (SIS 645UltraC)
768 mb DDR 333mhz
geforce4 mx 440 8x agp
20gb hd EIDE
cooling department.
1 X fan (power supply)
1 X Intel processor fan (useless)
1 X Side in fan ( 3 colours)
2 X front in fan (normal size)
1 X normal size exhaust fan back top
1 X small size exhaust fan back top
17 * 100 = 1.7 ghz.
now FSB i put to 125mhz for the best i can do and its settled at 2.14mhz now.
wat do u think of this speed ?
i also upped the vcore voltage from 1.725 to 1.775 and processor temp is around 35-39 degrees idle and 42-47 when its bz.
now i'm trying to build a water cooling so that i can up the boost more hehehe.
i want a minimum of 2.6ghz with my 1.7 478 pin celeron.
this is how i plan, im going to drop ambient temperature, raise voltage and run higher fsb speed
give me some feedback on watercooling....is it effective ? is it noisy ?
water cooling ah?make sure its real good...coz some top air cooling models can perform better than some standard water cooling kit...and the price is much more cheaper than a water cooling kit... ;)
water cooling is veli silence compare to air cooling from wat i know...
thanks for the feedback :)
hmm i hate to maintain the fan , ig dust and those dirty stuff always make the fan stop working or go slower...
and imaging i got like 6 fan i got to clean every 2 weeks or so cause my place here very dusty :)
errr..... most prob go for water cooling still....
The average oc limit is 2.3 ghz for this cpu. You can check it out here :-
http://www.cpudatabase.com/CPUdb/
