Online Altezza Parts Catalog
AE111_SEG
Folks,
Thought this might be useful for the members. Can somebody pin this up.
http://www.toyodiy.com/parts/
Instruction :
1) Choose " Select Your Car"
2) If you know your Chassis Number then under Option 1 Key in. Ie SXE10-00XXXXX.
OR
Go to Option 2 and choose Japan and Year of Make. You will be able to see the Altezza
Then Choose Auto or Manual.
Under search result click on the chassis code. i.e SXE10-AEAVF
3) Choose which part of the car you are searching the part for.
Enjoy.
BTW you can check the Year of Manufacture also. Key in Chassis number in "Search by Vin" and press the search button. You will be able to see MM YYYY
Re: Altezza parts catalog (online)
Err.. bro, this is already posted up in *Online Altezza Parts Catalog* by AE111_SEG.. which has already been sticked.. You thanked him yourself on 7-7-2009.. Instead of making another thread.. you could help his thread by posting the pictars there to help others know what that website has to offer (since both your source is the same).. IMHO.. :wavey:
ops.. my bad, will request moderator to join the thread (if can)..
thanks doppelganger for reminder. :)
I guess you must be pretty free these days since CNY is just round the corner...:rofl:
Imagine cutting and pasting all the infor from the Toyodiy site..:biggrin:
Just change my Radio Antenna Rod today with a the equivalent MYVI Antenna.
Bought the antenna from a Perodua Service Centre and paid RM 34 for it.
If any of you are interested, the part number is 86332-BZ010. The radio reception quality is the same so this will be a cheaper option for those that need to change their antenna.
Today just found out the ignition coils the part number is same as Altis 1.6 and 1.8.
The airflow meter is same as camry. Lucky altezza share some common parts.:biggrin:
90919-02239 : Coil Assy, Ignition.
22204-21010 : Meter S/A, Intake Air Flow
dear vj & all,
For altezza prior to 2001 model,
pls take note that Altis ignition coil 90919-02239
only same with altezza's model 2001 onwards.
for 98~00 model part number is 90919-02236 :hmpf:
* haiz... me cannot pakai cos mine is 2000.. :mad:
Just to add to AE111_SEG's discovery on the common used parts for Toyota...
1) 22204-21010 : Meter S/A, Intake Air Flow - Camry Model 2002-2006 XV30
2) 90919-02239 : Coil Assy, Ignition. - Altis Model 2001 ZZE122R-GEPEKD
dear vj & all,
Why cannot pakai. ? Doesnt work or the cannot fit?. :hmmmm:
since toyodiy web says the part number is different.
one is 90919-02239
another is 90919-02236
so i presumed there's some diff in the specification (either in the coil core, fitting, length?)
pardon my noobiness if i am wrong.
one is 90919-02239
You could be right.
Sometime there will be an improved part. In a proper EPC it will say Can "Sub"
Toyodiy doesnt really have this feature. So we dont really know if 98-01 can use 02239.
Btw the estimated price is around RM 200 per piece. If buy from singapore then the estimate price is RM 160. ( I called up toyota stockist).:biggrin:
nice...really helpful...was looking for altezza clutch release bearing item code...
my fren search the item for me and the price is unacceptable...:stupid:
Do u guys happen to know the market price??...:hmmmm:
I already ordered for exedy single racing...
