http://www.kcbox.net/images/g5w96bnxdiub3ripdw_thumb.jpg
Wanted to improve car's stability & handling but curious about the aftermarket part reliability ? Here, we are introducing the NovaRain series of strut bar for enhancing your car handling, leading you toward a better driving experience.
The car's handling and stability issue usually caused by the chassis's weight transfer during cornering . Car's chassic can be flexing and deformity when you are performing fast cornering, hard braking, heavy acceleration( if engine power is simply overwhelming for what your stockcar chassis can handle )and somewhat aggressive clutch - kicking...when more and more force apply on ONLY one side which can be easily more than 2 times than normal driving condition( tyre already exceed maximum grip force ) which will causing oversteer and understeer problem.
To deal with this problem, reinforce the structural integrity of the vehicle chassis is important. This reinforcement will prevent chassis flexing under severe stress from hard cornering. By reducing chassis flexing, we are able to divert the cornering force to the springs and shocks, not the chassis. Now the springs and shocks can do their jobs more effectively and efficiently.
Upgrading racing springs, shocks, and high performance tires will put a lot extra strain/stress to chassis, it can be causing the chassis flexing problem too. A high tensile strength of strut bar will be need in this case, reinforced side walls for increased rigidity which extremely flex resistant.
Here some pictures
http://www.kcbox.net/images/oppa7is2ejljq8ncteg4_thumb.jpg
http://www.kcbox.net/images/aa11w2vy01bs8hjv9pol_thumb.jpg
There Will be 2 different material available for choose ; Alloy and Steel
Alloy : Decent Strength, Light Weight, Can be flexing a bit under heavy stress ( prevent chassis damage ) *Suitable for daily-driving.
Steel : Great strength *Suitable for track use
Purpose: If you wish to have maximum reliability and driving handling, Alloy is the way to go.
If you wish to have better handling ( and you are not driving extremely and hard core cornering, steel is
a great option for you to consider.
Dealing method: C. O. D. around kl & pj area or by postage
Courier charge will be bear by buyer
Location of seller: Kepong, KL
You can PM/SMS/CALL!
Contact method: 016 - 337 9739 ( Kenny ) , 012 - 314 9981 ( Daren )
Please don't hesitate to PM us or any inquiry by phone call.
Kindly browse through the available type and models of your ride below.
Here some pictures
