Olympus Microcassette recorder
Juzailee
Hi,
I have 1 set of brand new Olympus Microcassette Recorder for sale.
The model is Pearlcorder L250.Comes with the whole package including box.Never used before.Offer me a better price!!
So for those are intrested pls call or sms me 012-3148903:X-:
A leader in both form and function, the Pearlcorder L250 Microcassette recorder features fast playback (to scan tapes quickly) and voice actuation (for hands-free recording). All in a smart, compact package with a stylish platinum finish.
Features
  • Fast play mode allows 25% faster playback, to more quickly locate specific passages
  • Electronic cues allow fast location of passages
  • Dual tape speeds give you up to three hours recording time on a 90-minute tape
  • A tape counter lets you locate important topics quickly
  • Recording level control is set automatically
  • Lightweight design-only 4.9 ounces-fits easily into pocket or briefcase
  • Cue/Review makes for fast, easy message monitoring
  • Auto shut-off feature conserves battery power
  • Tape-end alarm signals when to change or turn over Microcassette
  • Jacks provide easy connection for earphone, microphone and external power
Technical Specifications [SIZE=-1]Drive SystemCapstan driveTracks2 tracks, 1 channel monophonicTape Speed2.4 cm/ sec., 1.2 cm/ sec. switchableMicrophone SensitivityFixed sensitivity (automatic recording level control system)Recording Methodn/aVoice ActivationContinuous adjustment using volume knob in the VCVE (Variable Control Voice Actuator) recording modeSpeaker2.8 cm dynamic internal speakerOverall Frequency Response400 ~ 4,000Hz at 2.4 cm/ sec.
400 ~ 3,000Hz at 1.2 cm/ sec.Remote Jackn/aMIC Jack2.5 mm diameter, impedance 2k ohmsEarphone Jack2.5 mm diameter, impedance 8 ohmsPractical Max. Output200 mWContinuous Battery Duration TimeRecording time 11 hours (when alkaline manganese dry cell batteries are used by the Olympus testing method)Power SourceRated voltage 3V DCBatteryTwo 1.5V AAA penlight batteriesExternal Power SupplyA-321 AC AdapterDimensions4.4 in. (L) x 0.8 in. (H) x 2.1 in. (W) / 112.5 mm (L) x 19.5 mm (H) x 52.5 mm (W)Weight4.9 oz. / 140 g[/SIZE]
