Thanks for the input. Any particular type/model of oil filter for this Amsoil brand.Maybe try Amsoil oil filter. Amsoil claims it can last until 40k km if used with Amsoil Signature series oil, or 20-25k km with other oils.
this isn't as much the filter - it's more the oil. Use good fully synthetic oils and reasonably good filters like original manufacturer brands, K&N, Amsoil, etc.Thanks for the input. Any particular type/model of oil filter for this Amsoil brand.
I'm not looking for extending oil/filter change but into a better oil filtration for extending the life of the internal engine component.
I thought good/excellent EO and filter work hand in hand in prolonging your internal engine component.this isn't as much the filter - it's more the oil. Use good fully synthetic oils and reasonably good filters like original manufacturer brands, K&N, Amsoil, etc.
What car are you using?
Would you use for 40k km? Filter is filtering the oil and all the dirt is inside......Maybe try Amsoil oil filter. Amsoil claims it can last until 40k km if used with Amsoil Signature series oil, or 20-25k km with other oils.
My VR all the while been using Proton filter only, sometimes even made for proton filter when proton ones out of stock......lolthis isn't as much the filter - it's more the oil. Use good fully synthetic oils and reasonably good filters like original manufacturer brands, K&N, Amsoil, etc.
Personally no, probably try 20k km instead provided using Amsoil Signature series too.Would you use for 40k km? Filter is filtering the oil and all the dirt is inside......
Ohhh.. It's seems proton oil filter are good too, nice to knowMy VR all the while been using Proton filter only, sometimes even made for proton filter when proton ones out of stock......lol
Mind to share more info on the oil filter need to research more. TqEneos or Bosch are good stuff.
Your'e referring to Hyundai oil filter are great?Honestly, original filter is great, just dont not change it everytime u change oil.
I've look thru the Amsiol Ea oil filter, it has 99% efficiency at 20 micron, this is looks promising.Personally no, probably try 20k km instead provided using Amsoil Signature series too.
Pair with Signature series if want to try 40k km oil change interval. If other oils they cannot last 40 k km obviously, not just because of the dirt particles contamination but other chemical properties not able to hold that long.I've look thru the Amsiol Ea oil filter, it has 99% efficiency at 20 micron, this is looks promising.
Why it needed to be pair with their Signature Series? Will it not work as well with others EO.
Oh, same oil for 40k km, I thought filter 40k km, oil change 10k km with no filter change.......lolPair with Signature series if want to try 40k km oil change interval. If other oils they cannot last 40 k km obviously, not just because of the dirt particles contamination but other chemical properties not able to hold that long.
If it's paper based you'll be fine. Doesn't matter what brand because your car isn't going to be as stressed out as a race car. The average everyday car isn't going to stress the oil beyond it's capabilities anyway unless you extend oil change intervals.I've look thru the Amsiol Ea oil filter, it has 99% efficiency at 20 micron, this is looks promising.
