Oil discharged from cyclinder head
GTIEVO3
Dear all,
Wats the cause of oil leakage from the cylinder head tiub? Noticed that extraordinarily alot of oil was leakead through the tiub and smeared to the air filter. Thanks
Looks like excessive piston blowby and high internal crankcase pressure.
Try checking ur PCV..... ;)
some cases is caused by overfilled engine oil...normally its due to a high boost application.... some also caused by hi revs.... all this is normal to a light modded engine....if evrything else is normal, u might opt for an OCT...
Saw my mechanic yesterday and was told its normal as ive overfilled the engine oil, sometimes high boost and hi revs. Was advised to install a Oil Catch Tank. Btw thanks for all the comment
