check if any vacuum hose got disconnect, normally at your actuator....
cos the car also running like NA...no G force already....just now tarik2 got G force...now no boost n no G force....uwaaaaaaaaanothing to do with turbo kong or bov kong?haiya takut2....y ahh/.///cos the car also running like NA...no G force already....just now tarik2 got G force...now no boost n no G force....uwaaaaaaaaa
-crack manifold/banana (bocor)
-turbo kong/jam (shaft,fins problem)
check if got shaft play, check if the shaft is jam or anything, check ur intercooler piping, do a boost leak test, check ur actuator koyak already or ur flapper leaking boost already,check ur valve bent or not, check watever is possible, my adv is not to drive the car at all for now, fix this first before u go into bigger problems =)
mostly if turbo kong, u can drive but its hard, if shaft play got very noisy bearing grinding sound
sifu2, sila tolong
cheers bro![]()
