Nissan Sentra N16
nismo7
all the sifus out there,
is there anyone has supercharged their nissan sentra n16?
any suggestion where can i get it fixed?
u might be able to use the supercharger kit from nissan march,or from toyota series to try. all those (2nd hand from chop shop)cost u around RM600 ...not including the piping route yet.
u can even put a switch to on/pff the supercharger. when u r in race, switch on the supercharger...and u'll feel the difference!!!
onece u switch off, ur car still can run as normal. just no forced induction is taking part.
[snapback]843335[/snapback]​
:D Had done it bolt on turbo kit for S'pore N15 :D
you mean when switch 'on' the engine will act like supercharger and switch 'off', it will be NA engine? are you sure supercharger and not turbo charged? if supercharger, no need to worry about turbo lag
im very curious how to u supposed to switch "on/off" on your supercharged. The compressor was belt driven so basically its constantly boosting. For toyota, its control by throttle load. with more thn 25% throttle load, there is a valve eventually will open and boost press will flow in but the supercharged is consistence pumping
