Nissan Cefiro A33 Engine Mount
lks3011
Dear all Cefiro member,
Hi! currently i using A33 2002 running about 120k km, found that front engine mounting broken, need all Cefiro Sifu give some detail to confirm.
1. I need to change all 4 mounting instead of 1 broken mounting?
2. How much for all the engine mount?
Walau!!! :banghead::banghead:checked with TC...Front Mount about RM750...one side mount
RM388.
3. Where can get the cheaper wan?
4. Front and rear mount had sensor included? for what purpose?
bro, if u wan cheaper engine mounting, try Vanli Autoparts in Jln Ipoh. they r the main stokist for nissan spare parts. basically, just change the broken one will do and get the original. the sensors r for airbags if not mistaken
Thank Bro,
Will call up Vanli Autoparts tomorrow....just checked with Puchong Parts Shop, Front & Rear Mount arround RM580 per pc....side mount arround RM188 per pc. The Tauke shop also told me that Fount & Rear Mount come with sensor that why so expensive.
Check with Vanli Auto the front and rear RM545 each....found it from chop shop RM250 only, the quality still good, it come with vibration sensor.
mount don't use chop shop one la, new one can last minimal 3 years. rubber parts is better buy new. That is not the vibration sensor, it used to control the mount to be soft / hard.
ya agree, all rubber thing better use original japan stock will give u less problem & lasting too.
last time use chaplang brand for my absober mounting 4 month niah already crack.
Dear Bro,
Ya..agreed with u, but my foremen told me that if want to change new one better u change all 4 new mounting....total cost RM1500 not include labor yet....so change chop shop one c first lo. (front mounting still easy monitor.)
Thank for your info....just want to know how it control soft and hard? myself open out the sensor cover only c one shot pin just can shake up and down only....
mount is not easy to monitor, if the switch fail you get vibration that you may not know and cause others parts to fail.
You don't need to get the switch mount, if not mistaken you can use the original A32 mount too.
My A32 is using Switch mount, and i am thinking is the same as A33, will need to replace it soon cause i can feel the steering give some minor vibration.
Thanks bro,
If you buy the mount without switch one..just let me know cos i may want to change it also.
(mount with switch too expensive)
