newbies with satria 1.3 acceleration problem
john_unai
when I use gear 3 for my satria 1.3, the car like no power n its acceleration remain constant even when i press the accelerate pedal more. at one stage the car will suddenly speeds up. at 1st, i tot that was because of the clutch plate have worn out.however after i change the clutch plate, the problm stil occur. is it because of gearbox?anyone can pls help.
usually if for efi car common troubleshouting would be cleaning u throttle body, check for u fuel injector if got clog, change u fuel filter, change spark plug, or just check engine setting.
Mine last time got the same lagging respond because clog fuel injector..
