New Intake Manifold choice!!!!
dcloo
1,500 RPM
http://cms.skunk2.com/photo/f-263-0a65789ea1912b154916e6ecb09a8d43f8ffedf4.jpg
http://cms.skunk2.com/photo/g-263-972f8fc23e0272fdd64cfc32162e56a3cdd2d074.jpg
http://cms.skunk2.com/photo/g-263-18f193a47853cbe3c16c11b1283eda6a9896d351.jpg
http://cms.skunk2.com/photo/g-263-15d1f3890be7253740d2480920228975296cb07a.jpg
http://cms.skunk2.com/photo/g-263-767063a487fa05398f73207877da914d922f80ac.jpg
http://cms.skunk2.com/photo/g-263-5a5138dcc901283f6b61bba8717056d5c6446784.jpg
http://cms.skunk2.com/photo/g-263-689315cf8b7d48e576c2f39dafee75f9fb6e4a74.jpg
http://cms.skunk2.com/photo/g-263-a8e1592cd61f7545670b7733663667621dbdb89a.jpg
http://cms.skunk2.com/photo/g-263-ae13adf123843da9e74bd7884d5c1667bfd76b37.jpg
http://cms.skunk2.com/photo/g-263-83c9db1a05628bc48cbe280942fb7eea4905d815.jpg
http://cms.skunk2.com/photo/g-263-c707825b5131364654c8292ab771de100cd95229.jpg
http://cms.skunk2.com/photo/g-263-7c5030216622ad24957e891bf91e62c0b2305d13.jpg
From Page:
K-Series enthusiasts have been waiting for an affordable intake manifold solution for years, and the answer is finally here…almost. Pre-production versions of Skunk2’s all-new K-series intake manifold are complete, with plans to make final versions available to consumers shortly. Why should K-series fans care about Skunk2’s new K intake manifold? Well, for one, the manifold’s design eliminates clearance issues normally associated with the ’06-and-newer Civic Si RBC units, so common Civic and Integra engine swaps are no longer an issue. But there’s more to it than that. Although the Skunk2 intake manifold resembles the RBC version, it’s larger internally and has thicker walls, which means further porting is possible for those who require the extra volume. The Skunk2 manifold also bolts on without the need for special throttle body adapters and water neck fixes for most applications. Pricing $USD 450, details, and ETA to come…
http://cms.skunk2.com/id/226/K-SERIES-INTAKE-MANIFOLDS/
Bump: this thats still no comparision between our RRC Intake manifold
but for the intake desing
but for the intake desingn its look awesome...
no need adapter plate! they cancelled the composite intake project n came out with aluminium instead.. the emblem is very bling2..
look nice this intake...how many hp this intake gain bro...?:rofl:
Bump: this intake is for civic right..?
This still no ppl know yet cause will launch end of the month
many ppl was waiting for the result but from what i know its just a copy cat of original honda just like those B-series refined from stock
this intake will fit most of the k series engine but not sure about how to disable original EGR system will do or not
DcLoo,
What is a "EGR" ststem ???
EGR (Exhaust Gas Recirculation).. EGR function is controlled by vacuum valve 2 allows a specific amount of our exhaust back to the IM... exhaust will mix with the intake air and will help 2 cooling down the combustion process...
here some picture skunk2 intake installed on eg chasis
http://www.ff-squad.com/tech/k20stuff/s2manifold/RG_09621_res.jpg
http://www.ff-squad.com/tech/k20stuff/s2manifold/RG_09623_res.jpg
http://www.ff-squad.com/tech/k20stuff/s2manifold/RG_09626_res.jpg
but don't have dyno number yet compare to original HONDA RBC intake manifold:rolleyes:
if power made same/less its just like nice display but if made more power then will good:driver:
