as per title, my car using liquimoly 10-40 engine oil, oil went missing after 3 - 4K km drive after servicing with new oil. no visible white smoke & no leakage.
izzit engine oil burned bcoz of engine too hot? or other causes?
really need help
after service, the oil dip shown at max level (oil level at the top marking) after 3 - 4k km ride, oil dip shown oil level is in between the max & min marking. not sure how many liters goneOil went missing means loosing how many liters?
From what i understand, there is a slightly lower engine oil level after a new service with new oil filter. The engine oil went into the new oil filter causes the level of engine oil drop. You can follow what sifu 6UE5t's suggestion, top up the engine oil and monitor again.
If you are using same viscosity before and did not encounter this problem, on next oil change, change back to previous oil brand.as per title, my car using liquimoly 10-40 engine oil, oil went missing after 3 - 4K km drive after servicing with new oil. no visible white smoke & no leakage.
really need help
Sifu okay lah, don't taufu only.....hhahahhahahhah
Hahaha, taufu is good food what!![]()
Since when la I become sifu??![]()
Both you consider Sifu category edi la. I like your engine 2.5L V6, the sound and power are cun.
I think most will refer us as keyboard warrior......hhahhahahhahah![]()
Sifu touge with taufu like Takumi......lol![]()
from CPS owner uses liqui molly...we heard the same issue and they topup EO every now n then...
change to other EO resolve the issue...but this is happening among CPS owner around me
