Need suggestion : Malaysia Boleh workshop
drill
Dear all,
I need some recommendations on workshop that are able to do out of normal engine transplant with good workmanship and reasonable price, around Selangor or Melaka.
Im thinking to change my Kia Carens year 2002 engine to Mitsubishi GSR auto engine and another one is to put a supercharger for my Kia Spectra 5 year 2009 ( small one just to help the car to push a bit faster only, not aiming at any high HP).
Hope Sifus here can point me out the right direction. Thanks.
May be so... any suggestion?
It ain't easy to determine "good" workmanship, your current cars are also quite unpopular when it comes to transplanting and modding and i highly doubt local modders have enough information regarding the car's chassis, the most headache part is ELECTRICAL wiring.
Pardon my directness, i would strongly suggest you go with simple IHE or modify the current engine (PNP intake and exhaust), decent fuel map computer and call it a day.
Thanks,
Ken
Dear all,
wah. GSR i don't think is a direct swap for the Kia Carens. Need to do custom engine mounting points. Why GSR if i may ask? you can get 4G63 which is more reliable than a GSR CK. unless your carens is a 1.8?
Those special engine swaps - personally I'd find a shop that's near to your house that's got some level of confidence doing swaps. The nearer it is to you the easier it'll be for you to followup and keep a close eye on them. I could recommend a shop in Puchong which I'd trust with my car anytime but if it's too far for you - you'll be hard pressed to keep up with the work done and checking on their status will be difficult.
Yah! not direct swap better not do, especially if need a lot of modding. Spectra also if super charge, wonder easy to get parts or not?
Thanks,
Ken
Im not looking for just upgrading for the Carens. The Carens FC is not giving good mileage. No faulty sensors... Its just as it is... Had checked with a couple of other Carens owner... RM100 ron 95 can give around 180km for town driving. Personally, if its consuming that much of fuel, it is ok if it got power... But too bad it doesnt.
I dont see any issue on the electrical. Since im not going to change the body and dashboard wiring. Gonna take the engine wiring, which minus of some features, to get it started and going... Just a few tweaks of wiring. Mainly for the ignition switch and fuel pump. Worse case... A standalone will do...
Yup.. if its a direct swap, it shud be easy. Too bad it's not... GSR coz roadtax is cheaper and yes, mine is the 1.8 Carens 1. The one before citra.
I will consider yours ... I have my regular workshop which is nearby... But they are a bit busy. And I'm busy too nowadays. Still have my Mazda at the workshop waiting to be revive. Not solely their fault, the engine's head is with me... Still no time to polish it.
Mine is Spectra 5. The engine is the same as Forte 1.6 minus of the 6 speed which the Forte has... Most problematic is only to get the gearbox.
If it's the older sedan Spectra.... I believe i would simply dump in a Mazda engine inside.
Ugh sounds just too much hassle. Better just buy a real Mitsu or some MPV better than the Carens, maybe like an Innova. As for supercharging the Spectra, also another questionable decision especially since its a KIA and not a common car to play around with heavy mods. Maybe better also sell it and buy something like a Swift Sport.
Wow, that is very very low mileage. My ex colleague had one too, and he did mention very bad FC. He sold it off long ago. Yup, true also, like our turbos getting bad fc but got some power to play with.....
Still, Kia engine not many do performance upgrade, unlike Mitsu and Hondas......
If only I got the cash to change the cars instead of modding it
Im not into really heavy upgrade for the spectra. Just need a bit push for the pick up. I would have opted turbocharging it... Running a small turbine setup, but since the exhaust side is at the firewall, not much room to make for the turbo. Internally i dont plan to change anything, just to hook up the supercharger.
IMHO and coming from some one who did cross breed engine swap, it's advisable not to perform Mitsu engine swap to this Carens as i would predict you need to build a lot of custom parts to make it fit nicely as stock in the engine bay. Wiring is always an issue for any engine transplant, be it same breed or cross breed. Just the engine wiring is not enough, you will need BCM (for power windows, warning lights or any other crap) and TCU (if its not integrated into the ECU).
Personally i will not do it if myself isn't knowledgable enough to know of the issues and knowing someone i REALLY trust to perform the swap.
Thanks,
Ken
some random feasibility questions....
1)how much are you expecting the gsr to cost (lets say all in, inc workmanship)
2)how much do you think the super charger install will cost (all in, not just the sc itself)
If you really count carefully in detail, such modding cost might end up higher than the delta of trading off your cars to other more suitable cars. For example adding a custom SC kit into your Spectra could easily reach 10k even when already be very judicial in choosing the parts including most used items. Not to mention additional risks if blowing up your engine and transmission if not done well. Just too much hassle for such cars to be frank. How much would your cars fetch if sold btw?
recently i also search for 4G93 easily RM8k. if the GSR-T will be easily RM10-12k. Transplant workmanship will be 4-5k. That doesn't include all the other misc like parts.
standby 30k for this kind of project... it is going to be a price for some other car
