need some help!!!
ryanz88
hi there...i'm driving a kenari..recently i'm facing a problem.
every morning when i start my car,black smoke vil come out frm my exhaust:bawling:..
de car vil feel like shivering 4 awhile...once de engine get hot,i wont b facing this problem.
everytime de engine get cold...this problem vil happen..hope u guys can help me bout this prob THKZ a lot
Too much carbon in your exhaust. Get it cleaned. Other reason can be the improper burning of petrol. Do you use any additives in you petrol?
Cary http://www.hidxenonlights.com
just send ur car dcarbonizing ,change the plugs and send it for tuning .it will be better.
DONT SIMPLY CHANGE UR PLUG MODEL OR U WIL SUFFER FROM PISTON PROBLERM
3 slendar..yup one of the symptom i believe..
try out this trick..
when starting ur engine,
try remove ur cable plug one by one at one time one.. hear the idling..
is every time u unplug the cable(not the plug only cable plug) there will a different sound, each time..each cable.. try it out... if there is no diffrent sound of idling when u unplug the cable..there is something is not rite....
fuhhh..berpeluh aku nak taip omputih nak explain..hehehehe..
