Need help, SR20DET injector upgrades...
smaller CC injectors doesn't mean smaller power outputs bro, and factory settings always tune the injectors to feed more fuel into the engine, a heavier mixture of petrol into the engine means more heavier the car will start off, as most of the GILA KUASA guys out there will know, the more balance your air fuel mixture is to your engine, the more power you will get from it. If you want to test whether my theory is correct, try putting in a set of 550cc into an RB20det engine (6 units of injectors), and then try it with a SR20det engine (4 units). See if I'm correct, the difference is unbelievable!!!
tuning of proper air/fuel ratio is important to produce the maximum 'safe' power..
but smaller cc injectors does mean smaller maximum outputs.. y do u think people change to larger injectors?
comparing same cc injectors in totally different engines are unfair (6 cyl vs 4 cyl??)
i don't see ur point, and i don't see the relevance of comparing the usage of same cc injectors in 6 cyl with 4 cyl engines...
fact is, if u aim for more power.. larger injectors are necessary to feed more fuel (more power = need more fuel obviously).
dorifto_demon, go ahead and put in around 550cc injectors (or even 740cc ones). i reckon their enough for most of us (unless u want 800hp monsters i suppose :lol: )
larger injectors are needed when you do heavy mods on your engine, like larger turbine, this does not mean u use larger cc injectors are the best, the best thing for your engine to give the best performance is to choose what's sufficient and safe enough for your current or future mods.
My point in using same cc injectors in 4 cyl engine and 6 cyl engine is not the power output, its the response that you are getting from the engine, using 550cc injectors on a 6 cyl engine, u hardly can start your car, but if in a 4 cyl engine, it will start fairly easy, that's the difference.
how bout the price for ca18det injector???im looking for it to fit it for my nissan march superturbo.....plezz all nismorian
550cc in 6 cyl.. u can hardly start ur car?? r u sure?
i thought the stock rb25 has a 370cc injectors.. had to start izit? dont think so..
y would nissan put in those injectors if the rb25 will be made hard to start?
its juz underpowered a bit (but still pushing 250hp at least)
i dont see y its hard to start a car if using small injectors (the smallest stock that is).. they are lots of variables of y its hard to start, usually using too cold plugs.. but i dont think using 370cc in an rb25 would make it hard to start compared to the sr20det..
boleh start la kalau pakai 550cc pun.i tried la but enjin idling crazy la.then swap ecu trus ok.but then that time my wiring for z32 airflow also kacau maybe thats why idling unstable hehe.(last time buang turbine r32 rb20 also can start but the sound so loud hahaha)
best way, I think, is to swap the injectors along with your airflow + ECU.. and tune it while you're at it..
OT:
chipstar: noticed your location is japan.. where exactly if you dont mind telling me.. I'm located up north in Yamagata..
