T tms_ae92 Active Member Senior Member Nov 23, 2007 #1 bro.. wondering 3k rpm at 90km/h consider normal for bt 5speed.?? bside that, water temperature at the center normal..?
chuckie 500 RPM Senior Member Nov 29, 2007 #2 yes bro, that's right also. mine also same like that....my temperature show almost 45% from cold level towards hot level...
T tms_ae92 Active Member Senior Member Nov 30, 2007 #3 thx bro chuckie... glad 2 hear tat.. thought something wrong with my engine... but mine temperature is slightly higher.. urs consider normal..
caleb_5375 1,000 RPM Senior Member Dec 1, 2007 #4 can check the cooling system such as radiator and water level in radiator and radiator reservoir .....if radiator a bit sumbat then the coolant hard to pass by so the temperature will get a bit high lor ...
