wan pomen Junior Member Oct 27, 2012 #1 Hi guy..want to ask you guy about fuel regulator..what pressure adjust good for 101 Sc? Sent from my Xperia™ arc S using Tapatalk 2
Mr.Chaser 4,000 RPM Senior Member Oct 27, 2012 #3 If not wrong, U may try 3.3-3.5psi(stock), 4psi(modded) Last edited: Oct 27, 2012
wan pomen Junior Member Oct 27, 2012 #4 I adjust 3.5 ..try at 1st time ok.but after 2 - 3 day car become sentap²..Adjust to 3 and try again..same problem came..what happen actually? My reg is broken?
levin818 1,000 RPM Senior Member Oct 28, 2012 #7 Thats the problem. Never buy cheap product or you will just waste your money.
