Need Help! Car alignment problem..
the anti roll bar bengkok edi?
I went to another tire shop, they check all alignment is OK, they mention my new tire experiencing RADIAL PULL, is this common here in Malaysia??
so I Google RADIAL PULL :-
Radial pull is common and occur on almost daily basis. It can be a brand new tire off the rack and can create a pull due to conicity which is due to a manufacturing flaw, 80% of the complaints that come in pulling is cause by tires and not caster.
Radial pull can be caused by a defective radial tire construction or uneven tread wear. A misalignment of the belts inside the tire can cause a new tire to pull in one direction. Moving the bad tire to the back reduced its effect on steering. You may want to check into having the tire replaced under warranty.
