Need guidance: Toyota Corolla AE92 Blacktop 20v
Hello guys i need help here, I have a problem with my 20v blacktop it puffs out black/dark grey smoke when i downshift/braking and when i accelerate after braking.
Problem is it happens when i don’t turn my ac on it puffs a lot but when my ac is turn on it the smoke disappears and lessens.
I changed the spark plug to the NGK iridium ones and service with liqui moly 15 but the problem still remains. What could be the problem cause when it idles it doesn’t puff smoke or when driving, only when braking and accelrating after braking with the ac off it puffs out a lot of smoke.
Thanks sifuu.
1st is it still OBD 1 ? If yes try to pull codes. It looks like it is running very rich. Could be oxygen sensor.
it doesn’t burns that much oil.
yes fuel consumption is high.
stock engine only change is ngk power cable and air filter.
Blacktop ecu parameter range is quite big, so it might not trigger error code. Try change new oxygen sensor if its still using old one. It wont hurt and the old one might be needing replacement anyway
