Need Advise - Speedometer Partially No Lights!!!
options
Hi Fellows Thread-mates,
I have a small problem on my e7 ride. My speedometer suddenly "blackout" with those affected area is the whole right-side (fuel, temp & evolution indicator bulb lights is off).
But RPM, Speedmeter, all others switch check light (engine check, ABS, safety belt, door etc etc) are ok.
Have verified bulb, bulb socket swap and fuse but the problem still the same. Can anyone gives a clues of what is the possible root cause? :stupid:
Han, bside speedo did u recog others blackout too like cigarette lighter, cd player or main rear brake light...
if not...to narrow down your problem...can try plug n play with other member speedometer...
Only the light did not turn on, may be should try to plug other speedometer.
Thanks.
Han, straight away change to Ralliart meter or better still Stack Meter laa ... :adore::rofl::thefinger:
Your car preparing for Major upgrade liao maa ... might as well change to the above meters .... :rofl::rofl:
That's good bro, u cannot see the speed, it wont mentally limit u from going faster ... then u can challenge ur limit now ... ha ha
check the bulb first....then check the incoming current....and then check the circuit....then socket....then switch....ecu...fuse...battery...alternator....bra bra bra....if too troblesoom......just hantar to reliable wyreman to check.....make sure they knows...ur ride wiring....
